Question about Coleman Powermate Premium Plus 6250W Portable Generator
Craftman generator keeps stopping - Coleman Powermate Premium Plus 6250W Portable Generator
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
Under load? or idle?
Check oil level pressure switch and level
Posted on Nov 15, 2013
My diesel kipor 5kva generator wont shut by key ,
Caution
the manufacture is recommending a cool down period of about 3 minutes to prevent overheating of the combustion chamber. the following is from the manufacture on shut down procedure.
3.2.8Check Stopping of Generating Set
(1)Disconnect the load from the generating set.
(2)Turn off the air switch of the generating set.
(3)Set the speed lever at RUN position, run the generating set without load for about 3 minutes. Do not stop the engine suddenly, otherwise the temperature will increase abnormally, the nozzle will blocked and the generating set will be damaged.
Press down the stop lever. Concerning the electric starter, turn the key to OFF. Turn the fuel **** lever to S position.
Pull out the recoil starter handle until you feel resistance (at this position, both intake/exhaust valve are closed.) and leave the handle in this position. This prevents the engine from rust.
If the engine keep on running even after the speed lever is placed at the STOP position, either turn the fuel **** to the CLOSE position or loosen the nut of high pressure fuel pipe on the pump side to stop the engine.
Do not stop the engine with the decompression lever.
Do not stop the generating set with load. Stop it after the load removed.
the following link provides the complete maintenance manual for the diesel generator
http://www.rcremers.nl/webshop/handleidingen?download=20:handleiding-aggregaat
Jan 12, 2016 | Kipor Electrical Supplies
Why would the carbuertor on my craftman mover be leaking between carb and filter houseing
My first guess would be a gasket - you may want to repost this in the lawnmower section.
Sep 23, 2012 | Cars & Trucks
25 lb oil free air compressor craftman not building pressure
most likly the regulator is no good, some can be serviced, some are sealed units.
Mar 12, 2011 | Craftsman 33 gal Air Compressor 6 hp...
WHEN I START THE GENERATOR I HAVE TO HOLD THE START SWITCH ON TO KEEP THE GENERATOR RUNING.
The switch should be three positional.
The upper position is only for starting. Continuous running is in the middle (self holding) position. Lower position is to stop the generator.
If left in middle position it is not running you may have the switch bad, or the generator is stopped by low oil level.
Jun 03, 2010 | Watts Onan Portable Generator - 4000 ,...
My sdmo generator keeps shutting down temperature
http://www.aa1car.com/library/overheat.htm
Troubleshooting advice above link.
Sometimes it is the head gasket, check, it can be, incorrect fuel mixture, far too lean, exhaust should be a light grey color. Check enough oil in sump. ensure free flow of air all around machine.
Mar 28, 2010 | NEC Mitsubishi MGE 1800 Generator-Voltage...
Craftman 1/2 hp chain drive , stuck in down motion
The thing to do is remove the cover and watch the limit switch assembly. You should be able to see how it is supposed to work and determine what is wrong. A small gear on the end of the shaft turns the limit switch assembly to make contact and turn off the motor in each direction. Something may be broken or out of place. There is also a possibility your logic board is bad especially if you have had electrical storms recently.
Jul 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftmans generator
Snake oil if its a sears (ie likely generac) genny...as this oil will be just as good of an investment as this POS genny is
Aug 31, 2008 | Coleman (100076) Compact Refrigerator
I have a craftman generator and it's about 2years old and the motor has went out. would it be cheeper to buy anther motor or a new generator? Were can i find a motor?
Depends on cost of new engine, generator, and engine repairs. Personally, I would look at northerntool.com as well as harborfreight.com to find a replacement. Both have retail locations, might be one nearby and you can save the shipping charge.
Aug 19, 2008 | Euro-Pro Steam Generator EP8001 Iron
Coleman Powermate Premium Plus 6250W Portable Generator Logo
76 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
