Question about Peavey Procom ACE PRO COM MN100TPA TWO PLAQUE NATURAL GAS WALL HEATER WITH AUTO THERMOSTAT 10000 BTU Wall Mounted Panel
My propane wall heater sounds like a blow torch when it kicks on and shotts flame out the front. I tis one with the bricks.
  • 1 more comment
  • Dan Webster
    Dan Webster Oct 29, 2012
    I just looked at amazon on the model you posted and that is a natural gas model. If you have propane connect it will not work . That heater cannot be converted either. It is strictly a nat gas heater ONLY
  • Annella Simpson Oct 29, 2012
    I have the 5 burner . I dont know why it says 3. It is the Pro Com propane heater and I have been using it for 3 years with no problem. Thanks
  • Dan Webster
    Dan Webster Oct 30, 2012
    Remove the bricks and look for a busted burner. I bet it has a ripp in the seam along the burner holes. Seen it.
  • Peavey Master
  • 8,220 Answers
Get a vacuum cleaner and clean the dust off the bricks is what I would do.
Posted on Oct 28, 2012
  • Annella Simpson Oct 28, 2012
    Thanks I tried that but did not work.
My mother has a 3 brick wall unit...two of the bricks burn with a blue flame now instead of the inferred...should she replace that wall unit?
Hopefully, Becca the unit won't have to be replaced at this time. It sounds like the burner(s) is clogged and and needs to be cleaned To do this, turn the pilot light OFF and allow the unit to cool. Remove the front of the heater cabinet to access all of the inside workings. Carefully remove the 3 ceramic plaques and set them aside, where they won't get broken.Using a vacuum cleaner that has a hose, brush attachment and crevice tool. Vacuum all of the interior of the heater that you can reach with the brush attachment and crevice tool. Then turn your attention to the burner(s), Vacuum them thoroughly using the brush attachment, then switch to the crevice tool attachment and vacuum all the little holes on the top of the burner(s) thoroughly. Before reassembling the heater, carefully vacuum the ceramic plaques on both sides using the brush attachment. Be careful not to drop them. Then reinstall the plaques and the front of the heater cabinet.
Light the pilot and allow it to burn for 2 minutes, before turning the control knob to ON. Watch the plaques and the flames to see that burn as they should after turning it ON.
If the above didn't solve the problem, depending on the age of the heater, it may be time to replace it.
I hope this helped you and thanks for choosing FixYa.
Aug 16, 2011 | Reddy Heater RLP100 Portable Forced Air...
I have three Kozy World wall heaters. Two work just fine - the bricks turn red after the heater has been on for a while. The third one always burns blue and the flames 'lick' the top of the inside of the...
Yes, it sounds like the third heater has a Control Valve problem. It's allowing more gas into the system than what it's supposed too. Have you tried turning the flames down to a lower setting? If so, did it lower the flame height? How old is this heater and is cleaned and serviced at least annually? Are you using Natural Gas or Propane?
Please get back to me with the answers to the above questions and I may can help you.
Thanks,
Rich
Feb 07, 2011 | The Companion Group Kozy World Portable...
Kozy World propane wall heater
The ceramic "bricks" need to be heated evenly. Since 3 are good, I would have to assume the other two have a restriction. Maybe a spider in the orifices, If  you can access the "jet" where gas comes out, try using a paper clip or something similar to clear any blockage. If that wont do it, pull the burner, remove each orifice and clear. Good Luck
Dec 30, 2009 | Heating & Cooling
My propane furnace sounds like a blowtorch when it kicks on but it also happens to my cooking stove
Hi, working with natural gas and converting them over to propane for the country folk, I do indeed know the sound. You might want to take a look at the burner section for any signs of carbon,soot, build up any where.If the gas pressure has changed for some reason, you will get this blow torch sound.You would need the correct meter to check or measure the inches of W.C. Inlet pressure not to exceed 1/2p.s.I. Outlet for propane has changed over the last 10 years, you will now find on the MGV (main gas valve) for propane is almost the same as with natural gas.W.C. is a measurement used in reading gas pressures, stands for inches of water-column. Recommended pressures are well marked in manuals and on valve its self. Right at 2.5 to 4" w.c. So, check for carbon build up and clean if needed.If it burns radical, pressures should be checked with a gas pressure test kit.Yellow Jacket makes a good one. I hope this has been of some help to you, Sincerely,
Shastalaker7
Nov 17, 2009 | Empire GWT-25 Wall Mounted Panel Heater
Glo Warm propane heater started to go out. I blew out the pilot with air compressor. It is staying on, but the middle burner in back of the pilot light is flaming a little above the brick. The other...
sounds like when you blew heater out with air compressor you moved brick so flame isn't hitting bottom of brick like they should. You should try and put brick back on top of flame so that you don't get to much heat on the refractory of the heater.The refractory will take the heat for awhile then refractory will start to break down. Then you will either have to install new refractory or replace heater
Jan 17, 2009 | Desa International GWP20T GLOWARM Wall...
Flame shooting to high
call the gas company to have it serviced sounds like it needs it
Nov 23, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Reddy heater TB100 propane
Well it sound like you have all the components working. Try lighting it with a torch or long match or something. If it lights, then you may need to adjust the spark-er. You also may need to adjust the pilot. It may be too much pressure, which will blow out the flame, or its not enough gas. Make sure the pilot orifice is clear.
Mar 01, 2008 | Reddy Heater-30-55,000 BTU Variable
Flame Adjustment
Make sure the unit is operating on the correct gas, Natural or Propane (LP). The sound you are experiencing is either not enough gas and the flame is burning inside the burner port(s) or too much gas and the flame is much larger than it has to be. At any rate, get a technician to check the gas pressure entering into the home. NOW!
Sep 17, 2007 | Goodman GDS80904BNA Open Flame Heater
Peavey Procom ACE PRO COM MN100TPA TWO PLAQUE NATURAL GAS WALL HEATER WITH AUTO THERMOSTAT 10000 BTU Wall Mounted Panel Logo
744 people viewed this question
Top Peavey Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Peavey Heating and Cooling Expert? Answer questions, earn points and help others
