Question about Microsoft Wireless Controller for Xbox 360 (Blue)
Wireless controller every wireless controller i have is not working at all.the green lights are just steadly flashing..it all started after we bought our son his own 360.thats when all the trouble started,what can i do to fix this crazy problem.can someone please help me..thanks kevin
  • 4 more comments
  • ltrainsr Jan 19, 2009
    the same issue happened to me just now!! will that solution work?
  • kimlings98 Jan 19, 2009
    I tryed that soultion but it didn't work
  • millerman3 Jan 23, 2009
    I have the same problem nothin works!!
  • jon detrano Mar 14, 2009
    my controlled keeps flashing and my 360 consoul will not pick up the reception
    my wireless controler keeps flashing and will not be picked up by the console
  • Anonymous Apr 20, 2009
    My son's controller keeps flashing too but still works. We tried the solution suggested and didn't work.
    Problem Solver:
  • 9 Answers
You have to link controller to xbox under disk tray to right theys a small round button press this green rings flash, whilstflashing press xbox button on controller so it also flashes this will link them
Posted on Jan 03, 2009
You have to start with 1 controller at a time nd repeat the same steps depending on how many controllers you have im not sure exactly what i did but for some reason it made my wireless controller work you have to put ur controller right under the disk tray then on your controller there should be a little button on the top on ur controller between your LB and RB buttons with three little lines on the side press that untill u see that the lights are goin in circles then push the same button on the front of your 360 nd this should helpp
Posted on Apr 26, 2009
Gamestop Edge PS2 Wireless controller wont work. New batteries and the square control (router) box just keeps blinking green. I pressed the button for reconnect and it still does nothing I need...
If the light on the controller is flashing then the batteries are still good. There is a small reset button on the receiver that came with the controller. use a needle to reset it while it is still in the ps2. make sure that the ps2 is turned on and the green light is flashing on it. it should blink a few times and then the light on the controller should turn red. once it does then press start and your good to go.
Hope this helps!
Nov 08, 2009 | Gamestop Edge Wireless Controller for Xbox...
Xbox-360 wireless controller doesn't sync at all
my xbox e87a2ee.jpg joystick this spot of cable is broke and i dont know what is sequece of colours in cable?
Oct 23, 2009 | Microsoft Xbox 360 Controller
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
Can't sync my wireless controller to my xbox 360
Hi
Dono if you did this the right way but when the remote goes in to sync mode in other words the green light goes flashing around in a circle,you need to press the buttton on the console aswell till it does exactly the same only then will they sync and it will pick up
the remote.
Hope this helpes
PS if you would be so kind as to rate my service i would be gratefull
thx
Slitwrists
May 18, 2009 | Microsoft Xbox 360 Controller
Wireless controller
press the little buton on the controller and the xbox and it should register
Apr 26, 2009 | Microsoft Guitar Hero: Aerosmith with...
All my wireless controllers are just flashing a green light and will not work can someone please help me figure this out
have you press the button on ur xbox to link them up ? under disk tray to right small round button press this the xbox rings will flash green then press xbox button on controller this will link them
Jan 03, 2009 | Microsoft Wireless Controller for Xbox 360...
Wireless XBox controller won't sync with the PC adapter
I finally found a solution that works for me (most of the time). I bought a USB hub (un-powered at the moment) and the problem seems to have disappeared. The Hub however isn't the solution. Running the controller or the hub from the rear motherboard ports is.
I was initially using the 360 wireless receiver from the front ports on the PC which are driven by a different circuit on the motherboard than those from the rear of the PC.
When the receiver is run from the rear ports or in my case a hub powered from the rear ports it works most of the time.
Ocassionally the receiver doesn't link with the 360 controller however unlike last time when pressing all kind of combinations of re-sync buttons did nothing, all I do now is press the very tiny white button on the front of the controller and it links up like it should within 1.5 seconds.
I hope this helps guys as the controller is great when working.
Cheers
Karl
Dec 25, 2008 | Microsoft Xbox 360 Controller
Xbox controls problems
Press the small button on the xbox 360 console then press the big X button on the center of the controller. Will make the controller and console pair up and work.
Sep 15, 2008 | Microsoft Xbox 360 Console
I just bought a new logitech cordless action controller, and i tired to connect it to my new ps2, and the green light on the receiver keeps on flashing but the controller is not working, its not connecting...
Make sure that there are no other wireless controllers in the room to interfere with setup. Remove the batteries and start from square one again. I have 4 wireless controllers and had to do this to get each one to sync right.
Apr 27, 2008 | Video Game Consoles & Games
Microsoft Wireless Controller for Xbox 360 (Blue) Logo
444 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
