Question about Gateway 4520GZ Notebook
Vga not working properly
Gateway 4520gz
Video controller (VGA Compatible) download
For Video driver you need to download video driver from (Gateway website)
try to connect VGA port properly so that the monitor works properly.
May 22, 2012 | Gateway FPD2275W LCD Monitor
No display screen
Hi There,
Check the mention below instruction to solve this problem.
  1. Check the VGA cable on both side connect properly, PC side and monitor side.
  2. Check the VGA card in connected properly on motherboard.
  3. Check the RAM, should remove and fix it again as a same before.
  4. Change the VGA cable.
Thanks
Mar 26, 2012 | Gateway Computers & Internet
Bonjour, je viens de rinstaller ma machine gateway ms 6124 et le controleur video (VGA) ne marche pas si quelqu'un peut m'aider.merci d'avance.
(Cliquez ici pour le fran?ais!)Have you reinstalled the proper VGA drivers? The following link will bring you to the Gateway website providing the drivers for your machine. You may want to uninstall the VGA drivers that are currently on the machine. You can do this by right-clicking My Computer and going to Manage. From there go to the device manager. Right click the video device and click uninstall. Then install the VGA drivers you've downloaded from this website. http://support.gateway.com/us/en/product/default.aspx?partNumber=5386
Feb 08, 2011 | Microsoft Windows XP Professional for PC
When I turn on my computer the monitor stays on for about 30-60 seconds and then turns off..I hookded up a different monitor with a different VGA cord and it works perfectly..I also tried changing out the...
The power printed circuit board is failing, not
delivering the proper power to the main board and/or the back lamps. One can
have this board repaired inexpensively by a electronic technician. Email me at Sprint6@zoominternet.net
and we may be able to get your unit working properly again.
Dec 14, 2010 | Gateway FPD1975W 19" LCD Monitor
Is not audio on my gateway 4520gz operating system w vista business
Ensure that the sound card has not been disabled or uninstalled under device manager.
Jan 18, 2010 | Computers & Internet
NO SOUND CARD DETECTED . WHEN WIJNDOW MEDIA STARTS PLAYING I RECIEVE A MESSAGE THAT THERE IS NO AUDIO DEVICE INSTALLED
I went to this address, try this driver. Hope this works. Good luck. If I helped please rate me.-jmattes http://support.gateway.com/support/drivers/search.asp?st=pn&param=3727 ub_clear.gif Sound Downloads ub_clear.gif ub_clear.gif ub_clear.gif Description File Info ub_clear.gif ub_clear.gif ub_greylight.gif ub_clear.gif ub_clear.gif ub_clear.gif yellow_arrow_little.gif 9528287.exe - Gateway Audio Driver Version: 5.12.1.4010
Oct 19, 2009 | Gateway 4520GZ Notebook
Need Service Manual for Gateway 4520GZ
hello, you can download the manual on this webiste:gateway.com/manuals
Aug 12, 2009 | Computers & Internet
Screen goes off showing VGA with cable on the screen
This looks like a bad cable connection. Try using a new cable for the connection between the computer and monitor. If that does not work test you computer on another monitor to make sure you are getting signal output from the video card.Also check the monitor on another computer.This is to check and make sure the monitor is working properly.You can also try using a add on video card in the computer to see if you can use the monitor this way.If you still are having problems. You can use this web address to get customer from Gateway. http://support.gateway.com/s/PC/R/1013953/1013953nv.shtml. I hope this helps you with your problem.
May 16, 2009 | Gateway GM5259E PC Desktop
Replace keyboard
Laptop computers are VERY hard to work on due to the size of the parts involved and how easy those parts can be broken. Take your computer to an authorized repair center for peace of mind and the warranty on those repairs that an authorized repair center can offer.
Nov 07, 2008 | Gateway 4520GZ Notebook
Gateway 4520GZ Notebook Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
