Question about Ruud UAPA024 Air Conditioner
Pilot will not light rudd ukkaa048jk13e - Ruud UAPA024 Air Conditioner
Rudd furnace pilot wont stay
You have one of three things here
1. Dirty pilot, needs to be cleaned.
2. Bad thermocouple needs to be changed and pilot assembly cleaned.
3. Bad gas valve pilot solenoid call a repairman
Nov 09, 2014 | Heating & Cooling
Rudd furnace pilot wont stay lit
Have your local gas compreplace your thermocouple.
Nov 09, 2014 | Plumbing
Need to replace a RGDA-100A-AR Rudd
it could be a bad flame sensor. if the control board doesn't sense a flame it will shut down the unit
Dec 15, 2013 | Weather King Heating & Cooling
Goodman gmt070 inductor fan clicks on, pilot glows, nothing
Possible bad igniter...igniter should read somewhere from 50-90 ohms. If not it is going bad. Remove igniter (don't touch carbon silicon rods) see if you see minute cracks or white spots. If ohms testing reads in 90 or above range , replace igniter. ( note some rheem, rudd and weather king igniters normal ohm range can be 130-150 ohms).. You might also want to check the igniters connections and control board module to make sure the the igniter is betting the proper voltage to get the igniter hot enough.. 110 volts or about is the input norm to the igniter.
Nov 21, 2013 | Goodman GMS90703BXA Heater
I have Rudd hot air gas furnace. The ignitor sparks and lights the fire but as soon as the ignitor goes off the fire goes out, flame light doesn't go on. What could be the cause?
Hi, Check the flame sensor next to the pilot. It should be a ceramic rod with a metal tip that rests in the pilot flame. It may be dirty. Clean the tip with steel wool real good and make sure it is in the pilot flame good. This will cause that condition to happen. If this doesn't take care of it, get back to me and we will go from there. Should solve you're problem. Merry Christmas,
Shastalaker7
Dec 25, 2009 | Ruud UBHC Air Conditioner
Can't light pilot on rudd model urcf 07e24jkr
If your furnace indeed has a pilot, a thermocouple or gas valve is your culpret. Thermocouple is about ten bucks from The Home Cheapo so it is a good inexpensive start. That is the copper stick that the pilot flame hits. Turn off the gas and electric when changing it. If it still won't light then you will need a qualified HVAC tech to replace your gas valve.
Dec 12, 2009 | Heating & Cooling
Fails to ignite,sparks but pilot will not ignite. have had problems with pilot going our for about three months. Thought attic air flow was the problem. closed off air vents in area of heater. problem...
Sometimes the pilot orrifice get plugged up and need to be taken apart and cleanned,,,,,, adjust the pilot flame on the gas valve, or check gas going to the unit to see if the in-line gas valve is opening and closing.
Dec 09, 2009 | Ruud Heating & Cooling
I have an 1984 rudd 75,000btu forced hot air unit with pilot light, while cleaning unit an electrical connector broke off ! it looks like a blue plastic wing-nut, and It has 2 large black wires that go to...
The simple diagram for that specific problem it connected series to thermal cut off sensor.
The two black wires, One came from a power supply line (it means an active power
and the other one goes to the load motor) If you shorted it connection it will run the motor.
But it bypass the sensor.
Unplug the power then try to fix the both end of that black wire connected to terminal bolt of your thermal sensor by replacing the broken plastic nut with a new one.
Fit the nut thight to avoid electrical arch while giving power on at the start.
r_ic7
Nov 29, 2008 | Heating & Cooling
Relighting the pilot for a rudd heating and air
I dont know of any manufactor that makes a stand alone pilot anymore. (pilot you have to lite). The pilot should lite itself when you turn on the heat.
Sep 24, 2008 | Heating & Cooling
Ruud UAPA024 Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
