Question about Dryers
GE Dryer PBVH520EJ0WW
Leaking water from bottom
  • Gloria Mitchell
    Gloria Mitchell Oct 29, 2012
    Is it possible that there is a buildup of lint inside the machine?Little air from vent.
4 Suggested Answers
  • 57 Answers
SOURCE: GE front loading washer leaking
With only a limited amount of information, I would guess your door seal may be worn....but how can you check it? Take a reqular piece of paper (8.5x11) and cut a strip 1x11. Open the door and while holding onto the paper strip, put the strip in the TOP of the door and shut it to see how the seal 'feels' when you try to pull the paper out. It should be very hard, if not impossible to pull the strip of paper out. Now, do the same thing with the bottom of the door. Does it appear to be much easier? Without knowing the age of the machine, I might question the door seal. You might also want to check to see if the door might not be bent just a bit. Do this by placeing a long level vertically along the front facing with the door open, then check the door for level. It may be as simple as bending the top of the door out while you bend the lower part in.
Good Luck
Posted on Feb 23, 2008
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
Posted on Aug 25, 2008
SOURCE: my GE mod#tfx20jrxd 19.7 cu. ft. is leaking water ...
water is leakinf from the frnt right bottom of my refrigerator model TFX20JRXD
Posted on May 08, 2011
My washer is leaking and won't agitate properly.
I had a similar problem with my GE Washer that leaked, and still won't spin. I fixed the leak though. It was from the pump, which is in the bottom front, and somewhat easy to get to. I just removed the front cover, and the pump is on the right side. The pump itself was not broken but one of the screws was corroded with rust, so water leaked from that area. I just had to take it apart, put in a new screw to get a tight seal, and no more leak.
Mar 11, 2015 | GE Spacemaker Washer and Dryer Electric...
Troubleshooting a problem with high pitched squeaking in GE dryer model PBVH520EJ0WW Squeaks when load is small or nearly dry - repairman came to check it out and said he 'couldn't fi
Could be the bearings going, other possibilities could be that the drum is slightly misaligned and scraping against the housing, although that's not very likely, or a bad belt.
Although sometimes it's some obscure thing, I could be compleatly wrong.
Oct 01, 2014 | Dryers
I keep seeing a puddle of water at the bottom of my GE Profile refrigerator. I traced the water line, and it is not coming out of that. I cannot locate any drain pan. However, I can see a 14 x 16 sheet...
the drain is stopped it is just under the evaporator a hole in the center pull out draw you will see it. blow it out .may have to chip some ice away or use hair dryer to melt
Oct 03, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
We have a GE profile that we bought in 2007. We
Hi Sandy, I can assist you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jun 19, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
How do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Mar 13, 2009 | GE Refrigerators
Where is the drain pipe located in the side by side profile ge
in the back at bottom in freezer there is a drain hole which may not be seen due to ice but remove the ice and clear with hair dryer or hot water / larry
Dec 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dryers Logo
294 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
