Question about Woods Hardware & Accessories
Removing plywood from floor fastened with screws
I'm trying to lift 5mm ply wood from the kitchen floor which has been fastened down with screws, but most of the screws are covered by the floor tile adhesive which means I can't get to the screw heads. Is there anything I can do to make the job easier?
  • Woods Master
  • 5,245 Answers
Use hole saw to drill around each screw.
Use as small size as possible.
When plywood sheet comes up, you will have plywood circles on floor held down with screws.
Put 2x4 block against each circle and bang with large hammer, or pry each with big bar.
The repair subfloor.
Posted on Oct 28, 2012
Removing the left front motor mount of a 1990 Buick PAve
Sometimes, I use a hoist to lift up on the engine just a little. To use a hoist, you may have to remove hood.
Sometimes, I use a jack under the vehicle, to lift and support engine. you have to be careful with jack placement. I might use a thick piece of plywood as big as the oil pan, jack up on the ply-wood, if it even acts like it may cave-in, stop, try something else. Sometimes, I have used a block of wood on the oil pan engine flange, that flange is usually pretty thick. Other times, I have jacked up on the crankshaft itself, not the pulley. That crankshaft is a tough piece of iron. There are safety issues when working under or around vehicles. Safety is your responsibility. Because I can't see what your doing, I accept no liability.
Jun 05, 2016 | Buick Cars & Trucks
What do i need to know about installing wood floor
What type of wood flooring is it, is it glue down or nail down, engineered ( like plywood) or solid? Is the subfloor wood or concrete ect.
Always follow manufactures specs as far as acclimation, type of adhesive and expansion joints.
Feb 26, 2016 | Building Materials
I have a 1996 model clayton mobile home and I need to replace my floor. What is the dimension of the wood and how would I go about doing it myself?
the floor will be waterproof ply probably around 3/8 to1/2 " thick It will be screwed to the frame underneath . The problem is that the floor is laid first and then the cupboards /furnishings are screwed down on top. It will be a big job and will require some expertise.
Feb 07, 2015 | Cars & Trucks
How i fix my wobbly high chair
If you know someone that has a welder they could weld it . Or if you don't .and can get the pedestal loose from the base you'll see where the break is .I would cut a piece of plywood drill a hole in plywood the size of pedestal push it in plywood stand stool up push down . Till pedestal touches floor take drill .get some 1" self drill/tapping screws commonly called : TEK-screws put 3 screws in the wood at an angle so screws go into the pedestal to hold it tight paint or stain the wood.your handy work.
May 15, 2014 | Furniture
I want to build a skate ramp, however I need to know how to bend the wood into position?
For all but the top layer the wood should be bent with the grain. It bends much easier this way. The basic technique is to screw the bottom of your plywood in place, and have your helper(s) walk slowly up the transition bending it and holding it down with their weight against the frame as they go. Then you, and possibly others work your way up screwing in one row at a time. It's important to have the plywood held flush against the transition framing by your helper(s) when you screw it in. If you rely on the screws to pull the plywood flush, they'll pull through the plywood, or pull the plywood out of place.
Jan 13, 2013 | Sport & Outdoor - Others
When cutting 18mm ply wood using a straight edge after a few centimetres the cut curves under the material even with a new blade. thank you
Unfortunately that is just to thick of material to cut with a jig saw blade. Plywood is made up of several layers and your blade is trying to follow the grain on one of them. You can try a metal blade and high motor speed low travel rate, but it will quickly heat up the blade and warp it making your problem worse if you don't stop often. If you are trying to make straight and curved cuts, I have the best luck with a rotary cutter such as the roto zip, but plywood easily snaps the bits.
Mar 14, 2011 | Makita Saws
We have a 2006 Rockwood 5th wheel and the floor in front of the sink is becoming soft and don't know what to do.
The softness in the floor is probably due to water damage and rot. Because this is happening at the sink, the most likely cause is a leak in the drain piping. The trailer is not very old and I don't think that the source is from outside. It is still something to consider, after doing a good investigation of the sink piping. In order to fix your problem thoroughly you will need to find and fix the source of the water, as well as making repairs to the soft flooring.
Most flooring in 5th wheels like yours is a plywood base with an overlay of another flooring material. If you have carpet or vinyl over the plywood it will need to be pulled up to assess the damage. Depending on the extent of the damage, you may want to look into getting a professional to do the work. Your own experience, and how much time or money you have to put into the project, should guide you on whether or not you want to do it yourself.
You may want to go ahead and pull up the flooring, even if you are expecting to hire somone to do the work. This will give you an idea of how much work needs to be done. When you have removed as much of the covering as you think you need to, check the plywood for discoloration and softness. There may be rings of discoloration that will give you clues as to the source. These would be much like growth rings on a tree that get bigger as they go out from the source.
The softness of the wood (often called punkiness) will help you determine how much of the wood you will need to replace. Some of the discolored wood may be able to be saved. You should replace all of the soft wood and any wood that is starting to get soft. Cut out some of the worst to get access to the underside for inspection with your hand and an inspection mirror if you have one. At this point you should have a good idea of how much work it will be to put the floor back together after you cut out the bad pieces. You will probably need to cut out some good wood with the bad to get sections out that are easy to replace.
I recommend taking a lot of pictures as you tear stuff out to help in the restoration. The flooring is usually installed before the interior. This may make the repair much more difficult if the bad flooring extends under walls and cabinetry. A lot of careful deconstruction may be necessary to get to flooring under these things. Pictures will help you to put things back the way they were.
While you are taking everything apart, you should be looking for the source of the leak. You will probably need to turn on the water and let it drain for a bit. Keep an eye out near the area of most damage. This may be at the source or just a low spot that collected water. Either way it may give a clue to the location of the leak. Inspect the area under the flooring for damage to the framing and anything else that may be susceptible to water damage as well.
When you have determined how much of the flooring to replace be sure to choose the right material to reinstall. Your trailer probably has an enclosed undercarriage. You can probably use standard plywood for the repair. I recommend getting a marine grade plywood, though. This is a bit more expensive, but if there are any further leaks, it will stand up to the water much better. Be sure to get the correct plywood thickness, too. Measure a good piece of the original to be sure. You should also use new fasteners that match the original installed. Use stainless fasteners (also a little more costly, but best for the same reason as the marine plywood). Any good hardware store can find you matching fasteners.
When you are planning how you will replace the flooring take a lot of measurements and make drawings to help. Use what the original flooring looks like to plan the new sections. The framing under the floor should guide the sizes and shapes of the new pieces. If you can't make joints line up with the framing you should add a support under the joint that is attached to the framing. Plywood comes in 4 by 8 foot sheets, so your sections have to be smaller than that. Remeber that the flooring will need to support the weight of someone walking on it (and probably jumping on it if you have kids).
Once you have the repair planned out, cut up your parts and install them. This will be the easy part. The hard part is going to be putting the rest of the trailer back together as it was. If you paid attention to how all the pieces came out, and took pictures, it will be much easier.
Nov 30, 2010 | Electronics - Others
How do I build a frame that goes inside a brick recess to hold a microwave oven an electric oven and drawers below. The ovens are approx wide600mm drawers will be the same. The hole in the kitchen wall...
I suppose you could build a box in the recess (top, back, and sides) with 3/4 inch plywood and screw cleates to that at the correct levels. This would give you some decent wood to fasten the front trim to as well as provide a robust inner structure for your oven units to mount to. For the drawers, you can make a simple box carcass with the same material to fasten your hardware and slides to. With strength sorted out you can then concentrate on knocking up a pleasant fascia with the wood, tile or laminate of your choice. That's my thought on it. I bet you get a few good answers as that is a good thought provoking project you have there.Regards, Farmerbear
Sep 04, 2010 | RTO M-D Building Products Carpentry &...
What do you advise I put under my washer and dryer? I need to slide them out service but I don't want the leveling legs to scratch the tile floor which is limestone and scratches easily.
I put a piece of 1/4" plywood in front of the legs, stand on the plywood and lift the front legs onto the wood. Slide the machine forward until the back legs hit the wood and tip it up on the back and on to the wood. Cart it away from there if that is necessary.
Sep 15, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing machine moviment
did not stop the vibriation but movment stoped by installing three quarter in plywood under it glued ply wood to exsisting floor and screwed it down then put fences wood around legs works so far anyway
Dec 04, 2008 | Kenmore Elite 45986 Front Load Washer
Hardware & Accessories Logo
170 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
jdthefixer
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
