Question about Sunbeam SCM7808 Humidifier Replacement Wick Humidifier Filter SF235
Where do i put the filter on scm7808
I can not remeber shere the filter goes
I have the same problem ANY ANSWERS??
Posted on Jan 06, 2013
Can you add a prefilter to an oreck truman cell to grab the larger dust particles and decrease the zapping?a humidifier in the room helps but when the furnace is going it can still be often.
it should have a prefilter already on it. they have a screen looking filter that goes on the front of the cell. If you don't have one you need to get one. You should also have a charcoal filter on the back side of the cell, if not then you'll need to get one of those also, the charcoal is for odors and not for filtering dust. Putting any other type of filter in front of the cell will just be turning this into a filter type cleaner and will be defeating the purpose of the reusable Trueman cell. You may as well just buy a different cleaner if you don't mind buying new filters instead of cleaning the cell. I would recommend cleaning the cell every 2 weeks to keep it working properly. This will also keep it from snapping, if yours is snapping it's already too dirty and needs to be cleaned, if it's snapping right after it's cleaned then you have a plate that is arcing in the Trueman Cell, I have posted a fix for the ProSheild Models to stop the cell plates from arcing.
Feb 19, 2015 | Oreck Air Purifiers
Gas spits back if I pump too fast, and the check engine light is on --maybe a vent is clogged--Help!
GASOLINE in the air filter is a serious fuel injection problem....to be honest....I have never heard of such a problem...air goes through the filter into the cylinder where it mixes with gas....to have gas spit back into the air filter.......exhaust valve stuck? Maybe intake manifold is leaking? Gas from the tank goes straight into the cylinder via the fuel injection hose...how does it get into the air filter is really a problem. .
Dec 03, 2013 | aFe 2001 Ford Ranger - 2.3L 4-cyl. engine...
In what order do the filters go back in after I've cleaned them?
The honeycomb goes in first, followed by the mesh, then filter sponge, then the other mesh. Then you attach the filter lock plate. Hope this helps you.
Jan 27, 2011 | Ecoquest Fresh Air Air Purifier
I've replaced the filter. why won't the red replace filter light shut off?!
Remove the front cover and locate the FILTER RESET button above the dust sensor level indicator lights. Press and hold this button for 3 seconds until the unit emits a beep and the REPLACE FILTER light goes out.
Sep 03, 2010 | Winix PlasmaWave 5000 Air Purifier
Which way does the filter go? I'm replacing the pre-filter and the hepa filter. Is there a front or a back to either? The hepa is a white square that looks the same front and back, except for diagonal...
there should be a directional arrow to show which way air flow should go, if its framed it will have a pull tab that goes facing out, if it a piece that looks the same on both sides, it can go in either way, if it has a white side it goes facing in
May 22, 2010 | Kenmore 335 CADR Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Brookstone pure ion filters
You need to reset it, unplug the unit and take out both filters. Then, plug it back and and simultaneously and firmly slam both filters into the back of it at the same time. Before putting both filters back inside the until, also vacuum out the insides in case there is hair/dust inside of it that has accumulated.
Also, make sure your filters are 100% dry before every putting them back inside the unit.
Mar 02, 2008 | Brookstone Pure-Ion UV Air Purifier
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Bionaire Hepa filter
The carbon filter should have the air passing through it first, before the hepa filter. The carbon filter removes the large particles which would otherwise block the hepa filter very quickly. Contact these guys if you need more help; http://www.bionaire.com/contactUs.aspx Hope this helps :)
Jan 01, 2007 | Bionaire LC0760 Air Purifier
Sunbeam SCM7808 Humidifier Replacement Wick Humidifier Filter SF235 Logo
Top Sunbeam Air Purifiers Experts
Are you a Sunbeam Air Purifier Expert? Answer questions, earn points and help others
