Question about Savin Office Equipment & Supplies
Error code sc436 on savin c9065
Have replace dum,developer and corona and did complete pm on black pcu.
SOURCE: Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Posted on Nov 16, 2006
  • 37 Answers
SOURCE: Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Posted on Nov 16, 2007
Cogz
  • 1326 Answers
SOURCE: Setting Developer
I have No idea what copier you are tring to set..... The developer would work fine in another copier, it has been set already.. How is the OPC? New or Old? Need more info.... Is it a Minolta
Posted on Jul 17, 2008
Joed911
  • 4338 Answers
SOURCE: Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 10, 2008
FixinFax
  • 3085 Answers
SOURCE: My alert said to ''Replace PCU Black Soon'' ''Prepare a New PCU
That is correct.
Posted on Feb 27, 2010
Testimonial: "Thanks, why didn't the machine tell me to replace the Black Toner verse saying "Replace PCU Black?" What does PCU stand for? Thanks,Al"
Model 600. Why is it dropping toner near transfer corona unit?
When is the last time the developer and drum where replaced? When the last time was a PM done? Very 250,000 copies a PM must be done? Which replaces the Corona Wires, Developer, Drum, Corona Grid, Web roller for fuser (Hot Part). Also during the PM the Tech should clean the toner out of the Waste Toner collection unit on the image unit. also clean the area around the drum and developer roller.
Oct 28, 2015 | Konica Minolta bizhub Office Equipment &...
I have ricoh mpc6000 there is error code 300 how to solve
SC300 D Drum charge corona wire error: K
The output of the charge corona wire of the black PCU is abnormal. • CGB power pack connection loose, broken defective
• Check CGB power pack connection to BCU
• CGB power pack defective
• BCU defective
• Replace OPC drum More likely needs a new Charge assy. or Charge grid. Roughly $20-$100 for part(s).
Apr 29, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
How can fix this code C-2105 in konica minolta bizhup 600
C - 2105 Transfer/separation corona cleaning motor home sensor error code.
Remove the transfer/separator corona located in ADU assy,use the vacuum cleaner and clean the corona support and the 2 sensors(located under corona assy rear and front area).After cleaning urn ON the copier and is working.
Mar 16, 2013 | Konica Minolta Developer 02xk Dv710 for...
SAVIN 2055 WITH AN SC301 CODE
SC301 error code description:
Charge Corona Output Error 2
Charge Current Leak
Charge would need to change number of pieces corona wire A166 9516 (to confirm with the service repair center) Charge Corona Wire.
Hope helps (remember to rate this)
Sep 30, 2010 | Savin Office Equipment & Supplies
Savin 9927dp photoconductor ?
THE MAINTENANCE PROMPT COULD BE TURNED OFF BUT THAT IS AGAINST THE MANUFACTUREERS RECOMENDATION. THE PCU
WOULD LAST A LITTLE LONGER BUT IT WILL START DUMPING TONER AND DEVELOPER IN TRAY1 IF IT ISNT ALREADY THAT JUST ADDS TO THE CLEANUP TIME AND COST THE PCU WAS DESIGNED TO MAKE 60,000 PAGES.
May 06, 2010 | Office Equipment & Supplies
MY SAVIN 9922DP does not copy
With no error codes being displayed, this could be any number of things. The easiest to try is a new type 270 PCU. The cover over the laser write unit could be completely covered with toner (not likely). The transfer roller doesn't have any voltage going to it. That is the long black rubber (like) roller you see when you open the right side door. Check to make sure the contacts to the roller are all good and clean.
Anything else I can think of should give you an "SC" code.
Sep 15, 2009 | Ricoh Aficio 450 Copier
PRINTED PAGES ARE BLANK AFTER REPLACING PHOTOCONDUCTOR
The machine should automatically recognize the new PCU. Blank copies would lead me to think you have further problems, charge corona? transfer issues? If you try to make a copy and open the front door real fast when the paper should be at the transfer unit, is there an toner image showing on the drum? If yes, then you have charge but not getting transfer. This is a hard problem to troubleshoot without seeing machine. Anyway good luck, please rate this. Thanks ..... Wait... just had a thought. On the shaft, on the inside of the rear frame, that drives the drum there is a coupling that is spring loaded. Sometimes the shaft gets gunked up and coupling does not pop out not connecting to the PCU, which could cause blank copies and will still say replace pcu. You could add a couple of drops of oil to that shaft to loosen it up if that's the case.
Jun 30, 2009 | Savin Office Equipment & Supplies
AFTER PHOTOCONDUCTOR REPLACED PAGES ARE BLANK
IF you replaced the entire PCU, make sure you pulled the plastic tabs from the unit and removed the protective paper from the drum area. I don't remember if the new PCU comes with developer pre-installed.
If you replaced the drum/developer, it is common for the lower developer unit drive gears to wear down and break off some of their teeth.
Hope this helps.
Jun 30, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Savin CPL17 error message "486". I replaced the black PCU alreay, but the messgea still comes up.
I have a savin clp 17 and the error light has been on and it says color regis. The yellow is not mixing with the other colors. Please help.
Sep 02, 2008 | Office Equipment & Supplies
hope this helps
Oct 15, 2007 | Ricoh CL3000E Laser Printer
161 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
