Question about JibJab.com JibJab
Cannot upload new head on jib jab
I click on "add new head" on Jib Jab..but nothing happens..not leading me to my photos...
Upload pictures to my eBay account
  1. In the Add photos section of the listing form, click Add/Edit photos.
  2. Click Import from web.
  3. Find the photo you want to upload, and enter the URL in the field indicated. Click Add another to add more photos.
  4. Click Import to copy your photos into your listing.
Quoted from eBay.
Aug 29, 2017 | eBay Computers & Internet
How do i replace the glass in my rear window of my 98 oldsmobile bravada?
this is a job requiring experience as if it is not done properly will leak
Take it to a windscreen fitter and they will have the jib done within the hour.. Some windscreen fitters will even come to your home to do the jib.
Jan 16, 2015 | Oldsmobile Cars & Trucks
Hcl asus P5GL-TMX/S.i'm looking for sound and video drivers..i tried alot but haven't found yet
mere system mein ye problem hai ki jab power on hoti hai to muose mein light jalti rahti jab ki systam band hota hai.
aur jab system chaloo karta hoon to s.m.p.s se ek bar power cable nikal kar phir dubara lagani padti hai.
is problem ka hal bata den.
thank you
Apr 21, 2011 | ASUS P5GL-MX Motherboard
Unfortunately i don't have the manual and i need to change the blades on a McAllister Planer Thicknesser COD305P. Can anyone help?
I can help, but you'll need the gauge to set the knives exactly in the same spot on both or all 3. Do you have the tools that came with it? Do you have new knives or are you getting those sharpened? Getting then out is no problem, just take note of how they sit in the cutter head, loosen the jib screws, don't touch the set screws, take out all the knives, clean the jib off and the blow out the cutter head, sharpen the knives or get the new ones ready to go in, put the jib in, lay the knife on it, tighten up each end just snug, take your setting tool and just scrape the top on the knife, do not touch it, move it or stop on it, just shave it slightly, adjust it so it is just right, tap it back in with a piece of wood if you pull it up too far, do the other side the same, then snug up the jib screws, check the depth again, It has to be the same left and right, all knives, otherwise you will get chatter marks and speed bumps in your wood. Once it is set, tighten up all the jib screws, then tighten them again, do the other knives, all the same, do not answer the fone, get them all tight, put on the cutter guard, and plug it back in. You should be all set.
Jan 02, 2011 | Masonry Tools
May canon np 3020 ka machine liya hu. jab photocopy kiya jata hai to isme ek taraf kala aata hai. ye kis problam se aata hai
may canon np 3020 ka machine liya hu. jab photocopy kiya jata hai to isme ek taraf kala aata hai. ye kis problam se aata hai
Jul 24, 2010 | Canon Office Equipment & Supplies
How do you change the blades on a dw734 planer
Did you save the wrenches for the blades and the setting gauges? You need them. It is hard to do without. You have to take off the dust cover, should be called the finger cover, get the cutter head to lock up, it should have a pin on the right side to lock it from turning, loosen the jib screws,(bolts), and blow out he cutter head. Leave the adj screws where they are. Then do the other side, sharpen the knives, or get the new ones ready, don't answer the fone, or eat dinner at this time. The knife setter sets each knife to the same height and/or depth across the cutter head. It is a small C shaped thing that rides on the head and grabs the tip of the knife when it is at the right depth, they all have to be the same, and they just scrape the knife, they don't pull it or move it, it just touches it. Snug up the jib screw, and move to the middle, check and adj the height snug up the screw, move to the end, do the same, go back to the other end, check it again, use a small piece of wood to tap it down if you have to move it, when it looks good, torque it down, then do the other side the same way. I hope this doesn't have those tiny 2 sided knives in it? They are the worst, they have no meat, they don't cut worth a flip. You need the big knives, something with some meat to them. Check it out, hope this helps.
Jul 17, 2010 | Dewalt Planer (DW734)
My Computer,Mouse & Key Board suddenly hang ho jata hai
what is the company of your motherboard?????? this is important to know...then I am gonna help u.....
Feb 22, 2009 | Computers & Internet
Horizontal jib sheet power winch
Can u send the photo of this motor to my mail
khader_abu@yahoo.com
Aug 14, 2008 | Powerwinch Boating
EPSON STYLUS CX6400 ALL IN ONE
probably faulty or incorrect drivers, try using these drivers...make sure you uninstall the old ones
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=25723&prodoid=36478885
don't use the 64bit drivers unless you are using a 64 bit version of windows.
Feb 23, 2008 | Epson Stylus CX6400 All-In-One InkJet...
JibJab.com JibJab Logo
193 people viewed this question
Top JibJab.com Facebook Apps Experts
David Payne
David Payne
shuyumeng
shuyumeng
sdfOYXT
sdfOYXT
Are you a JibJab.com Facebook App Expert? Answer questions, earn points and help others
