Question about Refrigerators
G.e. profile refrigerator model PSS26 SGPA SS quit cooling after possibly leaving freezer door open overnight
Is there an easy possible fix for this, reset or clean out perhaps?
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Posted on Mar 25, 2009
SOURCE: I have a GE profile refrigerator. Model# is
You need to "reboot" the computer--unplug, count to 30, replug. Wait about 15 moinutes to see if it comes back. Our brand new one did not come up to temp until after we did that several times. Tunrs out 1 week later we had a catastrophic failure of the temp mechanism--it read properly but everything was warm. (the door was not left open) Ruined some very expensive food (steak, lobster) we were getting ready to entertain.
When we re-booted several times it got back to temp. GE refused to send someone out because eventually, the computer got "unstupid" and came back to temp. (They said if it was holding temp they would charge me for a service call--the unit was BRAND NEWI) finally got them to come out because I said it was not holding temperature. The technician took out the original board--which by the way had clearly markde on it that it had failed at least once in the pre-ship test phase, and replaced it with a DIFFERENT part number. Why, my guess that the original computer had too many failures.
Fortunately we have an extended warranyt--which we got because of the ICEMAKER, not the temp control. Give me back my old Kenmore fridge! If anything looks amiss again, I am insisting that they come out and replace the board. My guess is that the boards are throw away items that they don't test for what what wrong. (either too costly or they don't know what they are doing)
Posted on Aug 12, 2009
aasc
  • 1606 Answers
SOURCE: G.E. Side by side model quit dispensing water
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Posted on Aug 25, 2009
Testimonial: "The diagnostic aid was helpful. Still trying to figure out how to unfreeze the water line in the door of the side by side GE refrigerator, however. "
woodchuck789
  • 4066 Answers
SOURCE: Have GE Profile refrigerator Quit Working
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Sep 21, 2009
  • 20 Answers
SOURCE: Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
Posted on Apr 23, 2010
How to remove freezer door from ge profile pss26?
Probably has tub seal leak and got into clutch and rusted clutch if thats the case will need rebuilt
Jul 20, 2014 | GE Profile PSS26NGS Side by Side...
Frozen water on bottom of top freezer
The drain behind the panel at the rear of your freezer is most likely plugged with ice. The easy fix would be to transplant your freezer goods to another freezer, unplug the fridge and leave the freezer door open overnight.
Dec 03, 2013 | Maytag Admiral Top-Freezer Refrigerator
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
How to check stuff>
Sep 21, 2009 | Refrigerators
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 7 year old Amana bottom freezer fridge model ARB2259CW. The freezer seems like it's freezing just fine, but the fridge is either not blowing any air or blowing very little air. Things in the...
if you can hear a fan blowing in the freezer that is probably not the problem. If it is at all possible could you clear out the fridge overnight. If so, do so, unplug refrigerator with doors open overnight and plug it in in the morning. If it returns to cooling you probably have a defrost problem, but you at least have a couple days to fix it.
Jun 14, 2009 | Refrigerators
Psf26pgta
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile
  • possible causes:
Jul 02, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Moved refrigerator. Won't get cold now unless at 9.
  • possible causes:
Jul 01, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
