Question about Electrical Supplies
Centurion Generator 5000W/6250W - virturally no electrical output
Stored just over a year. fixed the clogged carb when it leaked gas. Got it started but voltage output in the 110plugs can only be read when voltmeter is set on 10V versus 250V. when set to 10V, output reads 11V. not enough juice to operate even a small drill. I would really appreciate any help from somebody. I'm waiting to not pull out the brushes since it looks pretty involved. Please help.
plkruger
  • 32 Answers
SOURCE: stalling on my coleman 6250w portable generator
ajust the float in your carb (bend the brass tab in that the top of the needle valve touches)and clean this needle valve. the bowl can be removed with a 7/16 box wrench on the bottom brass nut that is also a needle jet (clean this jet ,some models it is just a jet, others it is ajustable and needs to be 1 turn out to start then ajust wile running hot untill it stops surging) the problem is not allowing enough fuel to fill the float bowl
Posted on Feb 05, 2009
protek480
  • 1714 Answers
SOURCE: I HAVE AN OLDER POWERMATE COLEMAN 5KW. NO ELECTRIC OUTPUT
Around 75 volts DC
Posted on Aug 05, 2009
Testimonial: "SORRY FOR THE DELAY, YES AND THE GENERATOR IS NOW OPERATING NORMALLY. THANK YOU SO MUCH FOR YOUR HELP AND EXPERTISE. LARRY KINCAID"
  • 905 Answers
SOURCE: low output from NorthStar 5500PPG
There are a few scenarios that can cause this.
1) The extension cord that you are using is too long / too light of a guage. Try a heavier extension cord, or plug directly into the generator.
2) The alternator has lost its "residual magnetism" and may need to be reflashed. Consult Northstar for instructions and details.
3) The voltage regulator (actually a simple capacitor) may be "weak"
4) The diode for field winding may be bad.
You can get a copy of your manual here, page 40 has diagram and part numbers.
http://www.northerntool.com/downloads/manuals/165911.pdf?cm_ven=natural&cm_cat=netconcepts&cm_pla=Google&cm_ite=http%3A%2F%2Fwww.google.com%2F%26
Posted on Aug 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: i have a powermate 5000 that runs but no electric
Hi and welcome to FixYa, I am Kelly. I note your reading power at the brushes. Ok the wiring and circuitry is good to the brushes.
You can have all the eciter voltage present at the brush terminals but if the brushes are bad that voltage never reaches the rotor so you do not get any field voltage generated. I.e. no output.
You should first take a resistance reading across the terminals of the brushes to see if you have continuity via the brushes through the rotor winding.
No continuity... Remove the brush block and red the slip rings directly for rotor resistance.
Low resistance = good rotor.
No resistance = Bad Rotor.
That is only half of the windings.... The Stator winding will also have to be checked. There should be 6 stator windings. 2 windings will read about 15 Ohms each and one will read about 4 ohms.
If you have already changed the power head your looking at a problem with windings.
You should read 1.1 - 3 ohms white to black on the power outlets with the output power switch ON. No reading = switch/ wiring/ stator winding problems. (I.e... the 2 terminals of the powered outlets)
Thanks for choosing FixYa,
Kelly
Posted on Dec 08, 2010
  • 905 Answers
SOURCE: coleman powermate generator has no
Disconnect the leads going to the brushes, and check for continuity (resistance) of the field winding. You should be able to measure *something* on the order of a few ohms. If you have resistance, then check each brush contact to the shaft that the field winding is on. There should not be any resistance at all, if there is, you have a shorted field winding and will need to be replaced.
Check the resistance of the stator winding next, make sure that nothing is connected to the generator, disconnect the stator wires if you are able (label them!). Check for resistance between the leads (2 wires for a 2 pole, 4 wires for a 4 pole). If there is no resistance, then the stator is open, and will need to be replaced. Also check for resistance from each wire to the frame of the alternator, there should not be any resistance here (indicating a shorted stator). If there is, then you have a shorted stator, and will need to have it replaced.
Replacement is likely to be impractical, probably cheaper to buy another generator with the same engine and keep the old engine as a spare. Still, contact an automotive starter / alternator shop for prices.
Posted on Feb 08, 2011
I have a 2009 5500 wen generator with 10 hrs on it . Won't run without choke on.
Cloged or dirty filter or no filter or carburetor jet dirty or closed, bad gas some times to.
Mar 31, 2017 | Electrical Supplies
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Centurion 5000W/6250W starting - little voltage at outlets. I plugged in a voltmeter into the 110 plug and voltage is present, just a magnitude of 10 less than what it should be. so, there is 's
Try to find a way to ascertain if it is up to speed. Either check rpms or frequency of the AC voltage. If it is < 60 hz the engine is likely running too slow, thus the low voltage.
Sep 18, 2017 | Electrical Supplies
Centurion 5000 generator won't start after it sets for a month..why?
Maybe this article will be useful for you.
Why Diesel Generator Fail to Start
If you want to know more information about gas generator, this website will be useful for you. Gasoline Generator Set Gasoline Generator Data Supplier Exporter in China
May 23, 2012 | Electrical Supplies
Will not start. If I spray gas in the carb it will run for 2 seconds.
Sounds like no fuel, check for a clogged filter, stale gas, pinched fuel line. Check air filter as well.
Jul 26, 2011 | Coleman Powermate Premium Plus 6250W...
Hard to start & gas is leaking from bottom of carb. neck. generator has been sitting for a couple of years.
If it is a Briggs engine ther is a fuel pump on it and mine started leaking check that it is kinda behind the carb and to the left must remove the air cleaner and hosing
May 04, 2011 | Coleman Powermate Powermate 5000W...
I have a coleman 6250 generator, only runs when i spray fuel into the carb, it about a year old. With a B&amp;S engine
Old gas has probably gummed up the works. You have to store these with an empty tank to avoid this in the future. Using a fuel stabilizer helps too. To fix it, remove all of the old gas. Make sure the fuel cutoff valve is open (it only turns 1/4 turn). If it has a fuel filter replace it. Put in just a little fresh gas in the tank with a bit of carb cleaner. If it still won't run, remove the carburetor bowl and you will see a donut shaped float that operates a valve. Using carb cleaner, clean that valve, and clean the needle valve in the middle of the bowl. Good luck.
Aug 09, 2010 | Coleman Powermate Powermate 5000W...
My generator will not start after been in the garage for a year. It will run when I spray gas in the carb but not if it flows directly from the tank. I have removed the hose from the carb to make sure...
Sounds like you have a plugged needle valve in the carb.
You will need to drop the blow off of the carb and clean it.
The float valve attaches tot he needle and seat which also will need to be cleaned, air pressure is a good choice.
BE VERY CAREFUL SMALL PARTS WARNING!!
Mar 30, 2010 | Coleman Powermate Powermate 5000W...
My 6250 generator has been dormant for a few years. Worked well previously. Can't start it now. It will fire with stater fluid, but stall. Fuel line checked and ok. I think Carb. might have buildup that...
yes gas will deteriate and leave varnish deposits clogging carberator and layer in tank has yellowish color flush lines with brake cleaner and spray carb with spray carb cleaner and spray inside fuel inlet on carb let sit about 15 minutes redo and sit about 4 times clean fuel tank with brake cleaner (with tank off) until clean, refill with fresh gas and add about table spoon carb cleaner per quart of gas and let in run for awhile. when storing for any period of time add fuel stabilizer to avoid this issue in future
Jul 07, 2009 | Coleman Powermate Premium Plus 6250W...
Gas leaking after starting
leaks from where?
loose carb screws.
carb gaskit.
fuel line fitting loose.
Jan 01, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
174 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
