Question about Singer 7466 Mechanical Sewing Machine
Singer 7466 timing - Singer 7466 Mechanical Sewing Machine
4 Suggested Answers
  • 6 Answers
SOURCE: Can't seem to wind a bobbin on Singer 7466
HI, THERE ARE SEVERAL THINGS TO LOOK FOR WHEN YOU ARE WINDING A BOBBIN. FIRST CHECK YOUR THREAD, IS IT ON THE MACHINE GOING IN THE CORRECT DIRECTION. SECOND CHECK TO SEE IF YOU ARE THREADING THE THREAD THRU THE BOBBIN AREA ON TOP OF THE MACHINE CORRECTLY. I AM NOT FAMILIAR WITH YOUR MACHINE, BUT MOST HOME MACHINES HAVE THE BOBBIN THREADER ON TOP...THIS IS WHERE PART OF THE TENSION NEEDED COMES FROM TO WIND THE BOBBIN. NEXT, DOES YOUR MACHINE REQUIRE YOU TO LOOSEN THE TENSION ON THE WHEEL, OR DOES YOUR MACHINE HAVE YOU MOVING THE BOBBIN POST BEFORE IT WORKS. LASTLY, CHECK HOW YOU ARE ADDING YOUR THREAD TO THE BOBBIN AND PLACING IT ONTO THE BOBBIN HOLDER, IF IT IS NOT CORRECT IT WILL JUST SPIN OFF THE THREAD. I USUALLY LET THE THREAD GLIDE THRU MY FINGERS AT FIRST TO MAKE SURE I HAVE THE CORRECT TENSION. SOME MACHINES HAVE A TENSION SCREW THAT YOU CAN ADJUST THE THREAD TENSION. IF YOU DO NOT HAVE A MANUAL FOR YOUR MACHINE, GO TO SINGER AND MOST LIKELY THEY WILL HAVE ONE THAT YOU CAN PURCHASE. I HAD TO BUY ONE ONCE AND IT WAS ABOUT $15.00, MAYBE THERE IS A SITE YOU CAN GET ONE FOR FREE I DON'T REALLY KNOW. HOPE THIS HELPS. JUST A SLIGHT THING NOT CORRECT AND YOUR MACHINE WILL NOT OPERATE CORRECTLY, SO IT MAYBE JUST YOU HAVE SOMETHING BACKWARDS OR YOU NEED TO LOOSEN THE FLYWHEEL OR MOVE THE BOBBIN PEG.
Posted on Jun 17, 2009
SOURCE: The LED light on my Singer 7466 is not working.
yes
Posted on Nov 01, 2010
sjkirk
  • 11 Answers
SOURCE: Singer 7466 knocks loudly when sewing
Oil it; wherever metal rubs on metal. Take apart the machine; where there are small holes in metal pieces, oil it.
Posted on Jun 03, 2011
Singer 7466 opening plastic case?
you can remove the rocker switch this will allow you to move the case away which inturn will allow more access
Sep 05, 2008 | Singer 7466 Mechanical Sewing Machine
How to change light bulb on my singer 7466 sewing machine
Here's a manual for your machine:
http://homeappliance.manualsonline.com/manuals/mfg/singer/7466.html
Didn't find instructions re the light bulb but best guess is that the cover on the left side needs to be removed. Looks like there may be a screw that holds the cover in place.
Jun 11, 2016 | Singer 7466 FS, Free $30 Car Vac* FULL...
May 26, 2011 | Singer 7466 Mechanical Sewing Machine
I am having a problem with my 7466 singer. It was working fine then I heard a clunk and now I can not get the bobbin to catch any Ideas
Could be a bent needle, try a new one after you have cleaned out the bobbin area with a brush. Then totally rethread. You can call customer service at 1-800-4singer and they can advise you further. Hopefully, it is nothing serious. Good luck.
Sep 11, 2010 | Singer 7466 Mechanical Sewing Machine
I have a 7466 Singer sewing machine. No matter how I adjust the thread tension, the top thread always pulls the bobbin thread through to the top. I am doing thread painting. The feed dogs are lowered and...
Make sure to thread the machine with the presser foot up to insure the thread is seated into the tension control.
Always free-motion with the presser foot down.
Try a lower setting on the tension.
Mar 28, 2010 | Singer 7466 Mechanical Sewing Machine
Broken needle sewing through Corderoy
This machine should be able to sew 9 layers with no real problems but it may be necessary to use a bridge or hump jumper to go over the big hump. Set your stitch length to almost the maximum and sew slowly(one stitch at a time). If it buzzes just turn it off, shorten the stitch length and try again. The above applies if you are using regular thread. If you are using heavy thread, you will need to use a top stitching needle size 18.( It has a larger eye)and adjust your tension as high as it will go to remove the loops on the bottom.
sewman7
Dec 02, 2008 | Singer 7466 Mechanical Sewing Machine
Singer 7466 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
