Question about Philips Magnavox Progressive Scan Dvd Video/cd Player Mdv455 Plus Remote Control
I'm getting SUI dEO and my disc tray won't open
I turned on my dvd player and it displayed SUI dEO next to the power button and the tray for the dvd will not open. I tried unplugging it and then plugging it back in, but that didn't help.
5 Suggested Answers
SOURCE: DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Posted on Apr 28, 2009
SOURCE: No Power
I came up with this problem as well. I think the issue comes up when the unit over heats. I opened up looking for a power supply issue, and have not been able to find any capacitors that might have blown. First time this happened, I waited a few hours, and the unit slowly started to come back to life, and I was able to eject the disc. You can hear the player attempting to spin the disc, but failing to, then going back to off mode. Pressing the play or power button attempt to start the disc again.
This is only a temporary solution for this problem. I am working on finding the direct cause of this issue.
Posted on Jun 19, 2009
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
caroldon
  • 17129 Answers
SOURCE: Philips DVP5140/37 disc tray won't
What could be done is to leave the set Switched ON for many hours even overnight and see how it can change if there is a possible fault on the motherboard, a change of value in electrolytic capacitors.
If there is no result then there is fault in the motherboard and you need to take consensus for an estimate.
Posted on Nov 05, 2011
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
If press eject button,it's showing LOCKED.what can i do?
Jan 21, 2015 | home Audio Players & Recorders
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
Jul 09, 2011 | Samsung DVD-C350 DVD Player
if not working
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Philips Magnavox Progressive Scan Dvd Video/cd Player Mdv455 Plus Remote Control Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
