Question about Husky Portable generator
Husky generator won't start
Generator won't start. Has fuel, oil, new spark plug, etc. Help!!
    Problem Solver:
  • 8 Answers
Did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Posted on Jan 19, 2013
2 Suggested Answers
codi_medford
  • 8 Answers
SOURCE: husky generator 1850 watt wont stay running
does ithave fresh gas theres a chance there is water in the gas if thats not the case is the choke could be stuck on or the carb. is gummed up
Posted on Oct 29, 2012
My yardworks 2150w portable generator wont start. Thought it was dirt or water in the gas cleaned it all up .not working. Lots of spark no start. Help
My yardworks portable generator 2150 won't start - Fixya
www.fixya.com/support/t14802132-yardworks_portable_generator_2150
Oct 28, 2012 - First check the circuit breakers on the control/outlet panel. Then take the end off the generator and look at the brushes (usually what breaks) and the ...
Why won't my portable generator start? - Home ...
diy.stackexchange.com/questions/.../why-wont-my-portable-generator-st...
Mar 6, 2013 - The generator is fairly new -- I bought it at the end of June '12. ... An E 3 spark plug is always a good start, Stabil (fuel stabilizer)in the fuel or ...
the generator in parts, accessories - Alberta - Kijiji
www.kijiji.ca > Alberta > cars & vehicles > RVs, campers, trailers KijijiLittle hours on this generator comes with command start was over $ 500 just for the starter. Yamaha ... Yard Works 2150w generator. Generator starts ... Wanted generator for my camper at least 1500 or more ... You won't see more new motorcycles at one place anywhere else. ... New Champion 4000watt portable generator.
Power Generators New ' Kijiji: Free Classifieds in Alberta ...
www.kijiji.ca/b-alberta/power-generators-new/k0l9003 Kijiji
Dec 18, 2015 | Electrical Supplies
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
Why won't my Homelite 720 watt Generator start?
hi am elie hawzi i have generator 720wat homeliet had to run wer can i put 2 storc oil in my generator pleas do you have any adia haw can i leave the generator run stridaway thanks for fixya
Jun 28, 2012 | Electrical Supplies
I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
I have a husky 3750 generator about 2 yrs old. It is ony running on choke. As soon as you remove choke, it stops. I have changed oil and gas, clean the spark plug and check the air filter. Any ideas?
The fuel filter is probably partially clogged or the adjustment screw for the fuel mixture on the carb has backed off due to vibration. Try turning in the screw in 1/8 th of a turn at a time every time you start it.
Screws always loosen due to vibration so you only have to adjust in to fix it.
Regards
TickMagnet
Aug 15, 2011 | Briggs 3500W Port Generator
Generator won't start. Seems to not be getting fuel. The fuel is new. The on/off switch is on, spark plug new and generator was serviced less than 6 months ago.
have you had the generator stored with fuel in the carburettor since its last use if so the fuel goes bad and blocks up the main jet, remove the float bowl and clean out all the residue you can clean out the main jet with a suitable piece of wire
May 30, 2011 | Generac Electrical Supplies
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Husky Portable generator Logo
620 people viewed this question
Top Husky Electrical Supplies Experts
JOHN LAPIER
johnny rebel
Are you a Husky Electrical Supply Expert? Answer questions, earn points and help others
