Question about Yamaha RX-V671 7.1 Home Theater Receiver Black
CMK-P3X for yamaha reciver RX-V670 - Yamaha RX-V671 7.1 Home Theater Receiver Black
  1. I have a yamaha receiver rx-v670.But it's one of part is damage which we not identified.we found a number on part body.VP832 and XK593 CMK-P3K.Please any one inform me the part name.Thanks.
Posted on Apr 19, 2014
5 Suggested Answers
  • 979 Answers
SOURCE: RX V670 Yamaha Receiver-No big display, No amplification
It is entirely possible that your display tube has gone on the fritz. We see it a lot...accordianman
Posted on May 01, 2008
Bulldog AV
  • 52 Answers
SOURCE: hi i have a yamaha rx-v995 reciver and just
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
Posted on Nov 23, 2009
  • 127 Answers
SOURCE: RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Posted on Apr 27, 2010
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX-797 shuts down when playing at low
That would be consistent with reaching an overload threshold on the amplifier's outputs.
This is mostly boilerplate but it may lead you to the problem...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 20, 2011
Yamaha RX-V671receiver does not power on,
you should open the reciver, let it dry and with a thoothbrush clean the circuits.
it could help, but if anyrthing electric is burn inside you need to change it.
Sep 11, 2012 | Yamaha RX-V671
Re: Yamaha RX V670 Receiver Powering Off
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics ledstiles@hotmail.com
Apr 23, 2010 | Audio Players & Recorders
Hi i have a yamaha rx-v995 reciver and just percase new pioneer dv-320 dvd. it's output connection is with coaxial conector.when i connect the coaxial to the coaxial onector of my yamaha reciver i dond get...
Nov 16, 2009 | Yamaha RX-V995 Receiver
Yamaha receiver turns off seconds after being turned on
It sounds like the amp is going into protect mode.
Dissconnect all speakers from back of amp and then try to turn on.
If it works, you have a short on one or more of the speakers.
Jun 13, 2009 | Audio Players & Recorders
Cannot get yamaha rx-v663 to play DDTrueHD or DTS HD audio
If your Blu-Ray player has TrueHD or DTS-MA decoding, then it will send a already-decoded audio signal to your receiver. The receiver should then just recognize this as "Straight" decoding, because it isn't actually doing any decoding.
Hope this helps.
Mar 01, 2009 | Yamaha RX-V663 Receiver
Mar 19, 2008 | Yamaha RX-V661 Receiver
Need a remote Yamaha RX-V670
Hi there. Maybe you can get a universal remote that has the Yamihaha AND satellite codes in it. You can get them starting $25-30. Is they course I would take...:)
Good luck, thanks for coming to FixYa. A FixYa rating would be great:)
regards
Graeme
Feb 12, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Yamaha RX-V670 center channel failure
Change the pwr output stage semiconductors. Cost of parts should not exceed 10-15 pounds
Nov 12, 2007 | Audio Players & Recorders
Yamaha RX-V671 7.1 Home Theater Receiver Black Logo
718 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
