Question about Samsung DV448AEE Electric Dryer
DV448AEp no heat - Samsung DV448AEE Electric Dryer
Dv448aep steam problem
Try unplugging and replugging in the machine.
Nov 12, 2013 | Samsung DV448AGE Gas Dryer
Samsung dryer dv448aep/xaa drum not spinning. What do I need to do?
please checkthat the belt is not loose /worn /broke .
Aug 24, 2013 | Samsung Dryers
Samsung dryer hums but the drum does not turn
It sounds to me like the drive belt that goes around your dryer tub has broken.
images?q=tbn:and9gcqu5itfzbd0xyagva6nfwjbc486ekglruzljwmfemwgndlj-mg5tw
The back of the dryer will need to be removed to gain access to the problem.
Oct 27, 2012 | Samsung DV448AEP 7.4 Cu. Ft. Electric...
My Samsung dryer Model #DV448AEP/XAA has stopped heating. It runs but does not heat. The lint trap is cleaned out with every load and we have taken the exhaust hose off and cleaned the dryer and the...
I think your heating element is burned out. You can find parts at repairclinic.com
If you remove the element (unplug it first of course) you will be able to tell if it is burned out by looking at the actual heating coils. If there are any breaks in the wire anywhere you know its the problem.
Good luck
Dec 12, 2010 | Samsung Dryers
I have a Samsung Model # DV448AEP/XAA and it has stopped heating. We have cleaned the lint that we can see and taken the lint hose off and cleaned that out. The dryer is still not heating. Any assistance...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 12, 2010 | Dryers
How do I repair a broken element on my DV448AEP dryer until it can be replaced?
You can't do this. Sorry, once the element goes bad there's no temporary fix. Rich
Sep 26, 2010 | Samsung DV448AEE Electric Dryer
HOW DO I CHANGE A HEATING ELEMENT ON A SAMSUNG DRYER MODEL NUMBER DV448AEP
remove the kick plate if it has one if not the entire front has to come off
Apr 22, 2010 | Samsung DV448AEE Electric Dryer
Samsung DV448AEE Electric Dryer Logo
55 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
