Question about Manitowoc 1400 Modular Ice Machine Sd1492n
Won't make ice in cold weather - Manitowoc 1400 Modular Ice Machine Sd1492n
    Problem Solver:
  • 22 Answers
Check the thermostat of your Ice maker whether it is in working condition or not. For More information please visit GE Ice Machine Cleaner.
Posted on Nov 08, 2012
Won't start in Cold weather in Warm Weather it's fine
without actually hooking up a scan tool and looking at the pid data i would say you have either a coolant temp sensor issue or intake air temp sensor issue.i have seen alot more coolant temp sensors bad than the intake air temp sensors tho.
Feb 17, 2013 | 1996 Jeep Grand Cherokee
Gmc truck won't charge in very cold weather
must have a dead cell in the battery, only takes one . alwasy check the belt tension on the alternator,
Feb 05, 2013 | GMC Cars & Trucks
I have a 2004 Allroad. the temperature as of late has been extremely cold. Now the suspension won't raise at all. is it just the weather or is it the suspension itself?
Temp may cause slower response but it sounds like the cold may have caused a leak in the valve body or one of the plastic lines or bag seals.
Jan 29, 2013 | 2004 Audi allroad
Starter versus alternator for reasons 1997 jeep won't start - battery OK
yes, could be ! change your fuel & air filters , its winter time , yes !
Jan 25, 2013 | Cars & Trucks
My 2007 Milan won't start in cold weather.
Sounds like nonsense to me
Everyone drives a vehicle a couple days a week
If the battery is over 5 years old it may be bad
When you say you had it checked- we need technical
details of how it was tested & it's age
Was the alternator tested & again how?
If you haven't had anything tested in over a year,
you can expect things to not work as they should
Obviously your issues are somewhat weather or temp
related,so a fresh start & a different shop that knows why
your there & what you expect resolved is what is needed
Jan 15, 2013 | 2006 Mercury Milan
Since it got freezing last nite & now it won't
If the engine will not turn over very fast,it is most likely your battery.Cold weather will kill a weak battery a lots of times.
Dec 29, 2012 | Cars & Trucks
Truck won't start in cold weather
What truck would that be?
What has been tested so far?
Nov 24, 2012 | Cars & Trucks
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
On A1996 Chrysler Sebring, How Can You Tell If The Thermostat Is Not Working?
Most of time the termostat will stick open
& in the cold weather you have little heat
when it gets to around 35 degrees
For a small number of unfornutate souls it
may stay closed & overheat & even ruin the
engine because they won't stop using the car
Other than putting it in a pot of water on the stove
to test it
Just install a new one every 6 or 8 years
Aug 03, 2012 | 1996 Chrysler Sebring
Not cooling
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
The question is too short so i guess that your refrigerator maybe won't make ice & reason for not cooling so i gave this tip.
Have a good day. : )
Apr 17, 2011 | Kenmore Refrigerators
Manitowoc 1400 Modular Ice Machine Sd1492n Logo
109 people viewed this question
Top Manitowoc Refrigerators Experts
Tim Whalen
billconfused
Are you a Manitowoc Refrigerator Expert? Answer questions, earn points and help others
