Question about Smeg SUK61MFX Gas Kitchen Range
How to wire up my cooker
How to connect the wiring at the back of the oven
2 Suggested Answers
  • 417 Answers
SOURCE: How to wire SMEG Oven SA9066CER
Yes that sounds o.k
Posted on Nov 30, 2008
Why is my oven cutting out
If your oven is cutting out and this goes for anyone else experiencing the same problem.
If this is happening WITH ONLY THE COOKER. then either you will need the item looking at for proper earthing OR you will need the wiring checked for the cooker along with the RCD to which the cooker is connected as these can SOMETIMES be faulty.
Does the same happen if something else is plugged into the same socket??? If so then the socket and the wiring to the fuse board/ distribution board / consumer unit must be faulty or the earthing
Dec 14, 2015 | Ovens
How to hard wire to back of cooker
I gather your cooker has a cord and plug? The connections from the cord and plug into the oven would be where you connect the fixed wiring. This must be done by a licensed Electrician ( In Australia)
Sep 30, 2015 | Kitchen Ranges
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
When switchin on cooker it trips back off
make sure your electricity lines aren't connected to the ground(wire) on your oven
May 09, 2012 | Crock Pots & Slow Cookers
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
We bought a discounted display model Neff single oven from Comet and have booked an electrician to wire it in however there don't appear to be any cables coming out of the back of the cooker so how is the...
He will probably hard wire it from the terminal block inside the back panel of the oven into the cooker switch or outlet plate on the wall.(providing there is one, if not he will have to wire it back to the main fusebox) .
Dec 17, 2010 | Neff Ovens
Blows house trip when oven is turned on
Here is a diagram showing how the range receptacle should be wired. I would begin by checking there.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Apr 16, 2009 | Kitchen Ranges
Beko dc543 oven and top left top right bottom right hobs not working bottom left hob is working and so is grill i have checked all terminal wires and all ok i had this problem before under...
I AM NOT AN ELECTRICIAN ! But i have had the same problem of the oven and the back right ring not working and have found the cause of this. For some reason there is a thermal fuse running inline on a live wire inside the cooker if you feel competent yourself in replacing this fuse you will save a good deal of money on call out fees, here is how to do it. SAFETY is the crucial, First of all isolate the power source to the cooker, pull out cooker so you can get access to the back of the cooker, remove the 9 screws ( i think there is 9) to remove the back plate from the cooker, this is quite heavy because there is a small block of concrete fastened to the bottom left hand side of the back plate, looking at the inside of the cooker on the right hand side you will see a white wire which has been secured via a small screwed clip, this wire has a transparent sleeve covering the thermal fuse, remove the sleeve by sliding it up or down the wire, check the fuse by with a meter just to be sure, if it is blown cut the fuse out. replace fuse the same way it was fitted. replace the sleeve and fit the back on the cooker SAFETY FIRST switch on power and try oven and back ring, mine works fine. like i said at the start i am not an electrician, but i can not understand why there is a thermal fuse running inline to the oven which is linked the back right hob. all the best folks Hobbo from Chess.
Mar 23, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Beko Cooker dvc565
once you take of the back of the oven there are some wires going from the cooker to the back cover on one of the wires you will see a microtemp thermal fuse protector this connects the two wires (the white wire) this needs replacing you can get them from tdspares.co.uk we will be getting 121c degree. Hopes this helps
Feb 10, 2008 | Ovens
Smeg SUK61MFX Gas Kitchen Range Logo
56 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
