Question about Pride Victory 4 Wheel Mid-Size Electric Scooter
2008 pride victory scooter manual - Pride Victory 4 Wheel Mid-Size Electric Scooter
  • 118 Answers
SOURCE: Pride victory mobility scooter
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
Posted on Nov 27, 2008
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 175 Answers
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
Posted on Jul 07, 2009
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
Pride Victory XL-4 Mobility Scooter
You can get then from Prides website
Apr 27, 2017 | Pride Health & Beauty
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
Dec 03, 2015 | Pride Mobility Pride TSS300 Power Chair -...
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
I need a wiring diagram for my Pride victory 3 wheel scooter. Where can I get one mine is all messed up?
Try spinlife.com or call them at 1-800-850-0335. Maybe Customer support or manuals, technical assistance.
Jul 09, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
Pride Victory scooter repair manual
Piggies might fly = Pride don't want you to go anywhere near one.
Apr 10, 2013 | Pride Mobility Victory 3 Wheel Electric...
Can i order a owners manual
hi.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp this is the link to the pride mobility website where you can download manuals for all pride products free. there are 5 versions of the victory scooter. if you are not sure which one you have, click on the manual to view it and see which picture matches your machine. hope this helps.
Aug 02, 2011 | Pride Mobility Victory 3 Wheel Electric...
I have no manual for my Pride Victory 4 wheel mobility scooter.Where can I get one.
Hello i hope u 'll be fine.... thanks for using fixya.
You can easily get the manual for Pride Victory 4 Download it and Enjoy
You can also see lots of effective information of your product from this.
  • Manual is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u. Best of luck
Please do rate if it is helpful
THANKS
Mar 02, 2010 | Pride Victory 4 Wheel Mid-Size Electric...
Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
113 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
