Question about HP Photosmart C6380 All-In-One InkJet Printer
Printer error code Oxc19a0024
Tried all possible help from HP Support. The error message persists from the XP and on the printer screen - Ink System Failure. No printing can be done. All cartridges are full from the 'ink View' on the computer as all cartridges have been replaced a week ago.
SOURCE: HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Posted on Nov 21, 2008
SOURCE: can't print on 8250 photosmart printer
See http://www.hp.com/pageyield/articles/us/en/InkExpiration.html on how to override error.
Posted on Jul 03, 2009
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
SOURCE: Ink System Failure HP C5180
-------solution 1---------
HP C5180
Hidden tech menu For resetting and repair, FIX UIAUX
Fixes error 0xc18a0507 error ink system fail
press <left arrow> then press <setup> button together
then press <ok>once support R0631m comes on screen
right arrow 2 times to the System configuration menu
then <ok>
then <ok> to select and ok to confirm reset error.
then <cancel> to escape ( all of witch are onscreen instructions.)
presto restart and no further error
http://www.thecomshack.com/hpc7180.htm
------------- solution 2 ----------------------------------
HP C5180 All-In-One Printer HARD RESET:
Hold down HELP + OK button and unplug printer
Hold down HELP + OK button again as you plug the printer back in.
Then power it on, if it doesn’t power on automatically.
Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
Now you can release the buttons and simply power it back on.
I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
Posted on Sep 21, 2009
bandana_gyrl
  • 181 Answers
SOURCE: will not print, has error message 0xc18a0406. ink system failure
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Jan 21, 2010
Testimonial: "Wow, word for word to the tee. Even down to it reading R0631M. My printer works again, thank you soo much. If you were in Idaho I'd buy u a beer!"
Oxc19a0024 error
please toner seet is clean for cotton and install toner solve the problem
Apr 17, 2012 | Office Equipment & Supplies
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have a HP photosmart C6180 with Oxc19a0024
add andydragoescu on your y mess and y will try to help you!
Jun 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Photosmart hp 3310xi - ink failure???
Perform the steps given in the below webpage and if the issue persists then contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=in&lc=en&dlc=en&product=439491#top
Jun 05, 2008 | HP Photosmart 3310 Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart C6380 All-In-One InkJet Printer Logo
81 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
