Question about Frigidaire PLGC30S9EC Stainless Steel Gas Cooktop
Cracked ignition head on a Bosch PGL985UC cooktop
The middle burner has a cracked ignition head that needs to be replaced. How do I get the stainless top off the cooktop? Are there seals I will have to deal with?
I have bosch pgl985uc burner problem. The center burner will not stay lit. Seems other have had this problem. I ordered all new thermo-couplers. Installed, since Bosch changed them to a new part number...
If The Burner lights and stays lit as long as the knob is depressed, but goes out after the knob is released then there is a failure with the thermocoupler or the valve itself. The thermocoupler can be tested once removed from the cooktop - as follows
Heat the tip on the thermocoupler with a match or lighter and measure the electrical connection (other end) with a voltmeter - it should read about 15 mV or slightly more with in a few seconds. If no voltage is read then the thermocoupler is faulty and should be replaced.
The valve coil can also be tested for continuity at while the unit is disassembled. If no continuity is found the valve is faulty and should be replaced
The small voltage created from heating the thermocoupler energizes the coil in the valve which in turn keeps the gas turned on while there is heat at the thermocoupler.
Some units actually reignite the burner if the heat is lost and the control knob is in the on position.
Hope this helps ....
Dec 14, 2013 | Bosch PGL985UC 36 in. Gas Cooktop
Igniter stays on on the center and back right burner
If there is a relay it could possibly be sticking.
Oct 14, 2013 | Bosch PGL985UC 36 in. Gas Cooktop
The burners light, but it takes an inordinate time for them to stay lit. One of the burners will not stay lit when the knob is released, regardless of how long you depress the knob.
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
Jul 13, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
Can't find replacement burner knobs for my PGL985UC Bosch stovetop gas stove
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 21, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
Jun 20, 2009 | GE 30 in. JGP328 Gas Cooktop
Ingiter won't stop sparking.
You might have cracked the electrode if you were scrubbing next to it, otherwise you might try taking a little sandpaper and scuffing off any residue on the top of the igniter and seeing if that does the trick. Good Luck!
Feb 10, 2007 | Thermador PC366BS Stainless Steel Gas...
Frigidaire PLGC30S9EC Stainless Steel Gas Cooktop Logo
37 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
