Question about NAD C320 2-Channel Amplifier
NAD C740 no longer reproducing music through loudspeakers
Attempted to connect imac computer to NAD stereo (with RCA cable), in order to hear internet radio broadcast through my stereo system I tried plugging the RCA cable into each and every connection in the back, to see which one sounded the best. The connections I plugged into include: aux, phono, tape, and either pre out or main in. I think the problem started after plugging into the pre out or main in. I unplugged the RCA cable after hearing a faint pop. Now I can barely hear any sound out of my loudspeakers, unless I crank the volume to maximum. Even then, the music is extremely faint. However, I can hear the music perfectly when I listen through my headphones. Nice and loud... The small glass fuse inside receiver looks fine.
  • 45 Answers
What was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
Posted on May 20, 2007
SOURCE:
How do I connect my NAD cd-player?
If you have a receiver with a digital rca input, buy a good quality coaxial cable and connect it from the digital output of you cd or dvd player. The digital/analogue converters inside the receiver are almost always better than the ones in the cd player. If running cd to a stereo receiver, just use a good quality pair of rca interconnect cables. Red is right, White is left.
Jun 09, 2016 | NAD Audio Players & Recorders
My NAD C350 plays very faintly. when I turn the volume dial to the max position, I can bearly hear the music. I can hear properly from earphones output. Thanks
Take care. First put the volume down complete. Then unplug the head phone and than try to raise the volume. Could be the headphone connector does not switch through correct. Could be the connections between the pre and power amp are not in place or not proper pushed in?
Always take care when working with amplifiers. When switching them on with volume to max, you easy can kill your speakers. Also when disconnecting the headphones on full power kan damage the loudspeakers.
Aug 29, 2013 | NAD Audio Players & Recorders
Connect imac to amplifier
e4228d3d-a132-463b-8916-f7c5307ccb67.jpgI have looked at an image of NAD rear and it has RCA type jacks. I would plug it into the AUX sockets. Now to if it will work. Plug some stereo headphones into the iMac socket. If you can hear sound then the cable you intend to buy will transfer the sound you hear to the amp. If you want to record from the amp to your computer you will need another a different input on your computer and that would need to be connected to tape 1/2 out.
Any 3.5mm socket to RCA will do, they are not expensive plenty of cheap ones on Amazon and E-Bay (image shown). You will need two if you do want to record as well.
Aug 05, 2013 | NAD Audio Players & Recorders
I have a NAD C720BEE receiver and I'd like to get apple tv and run it through my stereo with this receiver. Can you tell me if this is possible. thanks, Letitia
You will be able to connect the apple TV to the Nad Stereo receiver. For that check the picture bellow of the apple tv box. There is two connector named Analog Wich you can connect to the input of the Nad. You can choose Video in put of the Nad. There is a need For a stereo RCA capble to interconnect both the apple tv and The NAD receiver. I have also added the picture of the RCA cable Which you need. After making connections Power on both apple TV and NAD. In the Nad receiver select Video in by Pressing the video button on its frond pannel.
Suarly you will get the audio.
If you need any more assistance feel free to contact me By fixya. Our you can conatct me on my email address ajingopakumar@gamil.com
Ajin
Mar 01, 2012 | Audio Players & Recorders
NAD C740 Chanel B Speakers not working The speaker output A is working properly, then the output B is completely silent. I install differents speakers and even the same speakers. no sound from the B...
possibly the causes are: 1. defective channel B power amp board. But try operating first with the built in tuner, if it's ok the RCA cable from your other sources(DVD player, etc...) might have broken internal conductor.
2. if it has the speaker switch(A, B, A+B) try toggling it, might also just loose contacts.
if the trouble is #1, leave everything to your trusted qualified technician, he knows what to do, unless you want to tweak/repair it by yourself...hope this helps ;-)
Feb 03, 2011 | NAD C740 Receiver
How do I connect to computer for music?
Please clarrify? Do you want to connect your computer to a amplifier and play music from your computer through the amplifier? If that is the case, you will need to get yourself a cable from your local sound shop. Ask for a "Stereo to RCA" cable. Plug the stereo jack into the back of your computer (where you would normally plug in your desktop speakers) and plug the RCA cables into one of your open channels on your amp. And there you go
Aug 01, 2009 | Technics SA-EX400 Receiver
How do i hook up polk audio speakers to the imac when the speakers have ablack and red hookup and the computer has a single hole for audio?
Your speakers need amplification. Otherwise you will not be able to hear anything, even at full volume. Once you have an amplifier, you can buy a 1/8 inch stereo plug to RCA cable (1/8" to RCA) from the computer to the amplifier. You'd then use regular speaker wire between the amp & the speakers.
Apr 01, 2009 | Apple iMac G4 20" Mac Desktop
DOWNLOADED MUSIC ON PC
Sure you can. Download the songs in MP3 format (check here how to download music) and then double click the downloaded file. One of Bill's wonderful programs will open and play the song on the loudspeakers of your PC. I suppose you have connected some to the output jack of your soundcard. If you don't like the sound of your speakers, you can connect the PC to your stereo by using an adapter cable from audio jack 3.5 mm to 2xRCA.
Hope that helps
Mar 16, 2008 | RCA RS2664 Shelf System
NAD C320 2-Channel Amplifier Logo
250 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
