Need sky remote code to pair with my tevion tv - model 30180 - lcd 40 inch
Need sky remote code so that i can use the volume and slicking through channels with sky remote on tv, any codes please? tried loads and have not worked! thanks in advance
SOURCE: Tevion LCD3210ID remote codes - Please Help
i cant get anything on my tevion television/dvd
Posted on Jun 14, 2009
  • 393 Answers
SOURCE: hi there i need code for sky remote to pair up to
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
Posted on Feb 28, 2010
SOURCE: need code
hi i have a baird or42bafhd tv and iv lost the book and need to no the specific features could you please help me
Posted on Mar 24, 2010
SOURCE: tevion lcd3207 cant find sky code. i am trying to
i have buy LCD TV for Tevion 32'' LCD Tv model LCD3207 PCB board 25114386.pls contact my e-mail
E-mail address: Kamfozi101@hotmail.com
Posted on Dec 27, 2010
SOURCE: need a code for my sky remote so that i can access the volume for my baird tv model cn42
the way to reset the remote is *press tv then hold select & red button, this will cause the remote to floash twice then key in 981 the remote will flash twice more then once on its own* hope this helped.....
Posted on Sep 24, 2012
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
Hi there i need code for sky remote to pair up to samsung lcd tv model number LE40b652,have tried 0060 in the book but not working sky bloke said that there is a tv model number code
Feb 28, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Need an activation code for my sky+ remote to operate the volume on my samsung lcd tv le40s8.
switch to sky on tv and press interactive on sky remote then move down to sky customer service (select) once screen has loaded move down to programe your remote you will need model number and make of tv press select and then enter the make of tv by moving down list once found select and repeat for model then follow on screen instructions
Dec 11, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Need to get volume on the sky remote to work,need a code
You need to bring up your sky help section which is all in the skybox look for menu or help and there is a list of all tv`s in there it will tell you also how to fix your remote, you will need to look for the model tv you have, you can also search online with your tv model and get it that way, which ever is easiest.
I hope that helps?
May 01, 2009 | Televison & Video
Sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Apr 26, 2009 | Televison & Video
Need code
Try this
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0117
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Mar 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Volume not working on sky remote
You will need a code in order for the tv functions of you sky remote e.g volume to work.
Click here to find out what remote control version you have.
If you have a remote control was produced after 2002 or there is no sticker
click here to use Sky's code look up tool.
Most SKY+HD Remotes are produced after 2002
Mar 21, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Pair sky+ remote to tv
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
Jan 10, 2009 | LG 42LG50 42 in. LCD HDTV
Code to progarmme Tevion TV
Might be a bit late - but I hope this helps..
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Jul 22, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
