Question about Sony KV-36XBR450 36" TV
Sony kv-36xbr450 36
My tv keeps turning off on its own while standby button keeps blinking 6 times apart. WHAT COULD THE PROBLEM BE?
    Genius:
  • Sony Master
  • 2,432 Answers
Breakdown in the horizontal, check the c515, c516 and the jungle ic IC206 which get bad.
Posted on Oct 28, 2012
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Posted on Jan 10, 2009
localwonder
  • 6784 Answers
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Posted on Jun 21, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 8457 Answers
SOURCE: sony wega KV-36FS13 standby light blinking 5
Ur power ic inverter board is dead.
U need a new one.
Posted on Aug 23, 2009
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Jun 18, 2012 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega tv won't turn on. The standby light blinks six times..
sorry, 6 blinks is a bad board!!!will cost around 1000 bucks,just by a new set
Oct 09, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My KV-36HS500 doesn't turn on.
You will need 2 MCZ3001D or MCZ3001DBs and two 18 pin IC sockets. the chips are on the d-board inside the tv.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Low HV Shutdown:
On the D Board.
Good Luck
Dals123
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-32fs120
The 6 blinks mean no horizontal. Check the horizontal circuitry. I'll look up your specific model later and post more details.
Dan
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36XBR450 36" TV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
