A vizio flatscreen that will turn on and nothing else even from the side of the tv its just hooked up to a ps3
  • 14,381 Answers
Say you just hooked something up to it,what?
Posted on Oct 27, 2012
  • 267 Answers
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
Posted on Feb 06, 2009
phongnv
  • 56 Answers
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
Posted on Feb 16, 2009
SOURCE: 32" Vizio Flatscreen TV will not turn on.
I had a lot of problems with the same TV but i'll be watching it and it will go full volume with static and turn off by itself then i would have to unplug it from the wall. then it would work fine for a day or a week then do it again. but today it did it and it wont work the yellow light is on but wont turn on.
Posted on Sep 19, 2009
wbigtodd
  • 19 Answers
SOURCE: our vizio flatscreen tv just went off and won't come back on.
Look and see if the fan is working on the inside.
It may a built-up of dust.
Thanks,
Wbigtodd
Posted on Jan 01, 2010
  • 5 Answers
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Posted on Jan 25, 2010
Lines on my vizio flatscreen
next, replace t-con and videoboard
Aug 01, 2017 | Vizio VO370M LCD TV
I switched my ps3 from one tv to my vizio, and the voices of the characters arent being heard, but all of the background noise is. i have it hooked up with an hdmi cable, and the video is fine. i checked...
Shot in the dark here, but sometimes HDMI cables get a little discombobulated... Try doing a hot plug by powering both the TV and the PS3 up and then removing the HDMI cable from both of them at the same time. Wait 1 minute, then plug them both back in at the same time. Good luck!
Jul 21, 2011 | Vizio M221NV 22 in. HDTV LCD TV
Got a PS3 hooked upto a Samsung 40" LCD TV via
I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
Hooking laptop to tv says invalid format on my
After it is all hooked up. You must go to main computer screen, then right-click on main windows screen,
You will see box #1 and box#2
Take the #2 box, click and hold mouse button and drag to the Left Side of #1 and let go of mouse. Get it as closely matched up to the #1 box without crisscrossing them. Just set it directly next to the box.
Then click enable this monitor and/or apply button.
Then ok,
Now your monitiors should all automatically connect and turn on.
Feb 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Im a girl, & i need help hooking up my ps3 to my flatscreen
ok it should all go into your tv ok? and there should be a row of yellow white red or any order (ON THE FRONT). you should look on the back of your tv or side for alot rows of inputs and each row should be for an different input on your tv like input 1 2 3 4 5 6? you follow? so just match the colors up on the back or side of your tv or front do not hook it up to your cable box..........Ahh i see the cable box is using the yellow one well maybe unplug that while your playing or there would prolly be other (RED WHITE YELLOW) on the back of your tv like i said or on the side
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
Vizio HDTV totally not workinig
It sounds like a problem with the power supply. I had the same thing happen on a TV that was only a couple of years old. It did the same thing that you have mentioned. Once in a great while, it would turn on, and then we'd just leave it on because we didn't know when we would be able to get it to work again. The problem was, to buy a power supply for it we could get another TV. It just wasn't worth it.
Your flatscreen might be under warranty. I would look into that.
Jun 11, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
What is broken my hdmi cable,ps3 unit or the hdtv?
I would suggest this (you haven't said what kind of tv you have). I have a 37 in vizio, and a 25 vizio flatscreen HD tv. I had my PS3 hooked up using HDMI first time I tried it I got the little pixels you were talking about...so do this. Sounds stupid but it helped me. The HDMI cable where it plugs into the tv plug and unplug a couple times (three times worked for me. Do the same at the PS3 side of the cable. You want to do this with both of the machines off. Also make sure you have the PS3 configured appropriately for your TV settings...There is a way you can auto setup the screen and sound by shutting the PS3 off and holding your finger on the power button for like 5-10 seconds (it will beep twice) then let your finger off the power button.
When my HDMI cable went bad it would go from having a picture and sound to having no sound and a picture, to no sound and no picture. I thought I had a bad HDMI slot...but it was just a bad HDMI cable
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
I have a 50 in vizio plasma. just hooked up a psp3 for the blue ray, but the input only says 480. What gives? shouldn't this be 1080? I can't find an ajustment on the menu screen on my tv?
What you need to do is hook up your PS3 to a different tv. Then in Display setting on the PS3 change it to 480p. Hook it up to your vizio and while on the ps3, change it back to 1080p. Most Vizios don't have a Progressive scan that adjusts to the output settings of the PS3 (or other device) .
Apr 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio flatscreen broke
There is no repair that would cost less than replacing the TV.
Feb 20, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
I turn on my ps3 but nothing appears on tv
Maybe u have the wrong cables hooked up if your tv does not have HDMI hook up then you are forced to use the cables that came with it. Make sure that they are correctly hooked up it should be color coded.
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
