Question about Gaggia Unica Bean To Cup Coffee Machine
Knocking sound when using steamer - Gaggia Unica Bean To Cup Coffee Machine
How can I get my steamer to work again? Orange light comes on but nothing else
Make sure you didn't knock off a wire to the heating element when you had it open. Also put a couple of cups of whitevinnegar in it and leave it for an hour or two. This will dissolve the scale build up. If it doesn't get hot thenthe element is probably burned out. There is a limit switch held against the tank too. It can stop the heating element if it goes bad.
May 29, 2014 | Rowenta IS9100 1550W Precision Valet...
What are the advantages of using a steamer over an iron?
steamers are usually believed to be easier to use and less damaging to the fabric over time
Jan 30, 2013 | Garment Steamers & Presses
Hi There,i need to know,my russel hopps steamer is making a beep sound the whole time. what am i doing wrong? the sound is very annoying
Hi, ok I also had that problem whereby the steamer keeps on beeping. It's a warning alarm. we need to fill the steamer with water directly into the reservoir and NOT into the side. the side is only for top up during the steaming process.
Hope this helps.
Sep 27, 2011 | Russell Hobbs RHST3 Rice Cooker
I just purchased a used EuroPro Steamer model EO8020. After about 5 minutes of use on the steam setting, the base starts making a loud rattling sound. Doesn't sound healthy to me. Can you...
It's just normal to hear that because heat inside is generating and steamer is on it's way to be ready for use. Hot air is about to be release and so rattling sound occured.
Need not to worry about it, the steamer is new and functioning normally.
Good luck
Jun 25, 2011 | Euro-Pro Steam Generator EP8020 Iron
Why does the pump make a knocking sound when using the steamer
The steam is hitting water somewhere in the tubing....this is not a problem... it's just the natural reaction that happens when very hot steam hits cooler water...
heatman101
Apr 17, 2011 | Breville ESP8XL Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
Dirty steam cleaner help
You can just run plain water thru it. But, the best way to clean it is to first knock all the stuff loose you can with a brush.
If you want to put detergent in it., use use liquid laundry detergent -- a small amount
Apr 30, 2009 | Vacuums
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Gaggia Unica Bean To Cup Coffee Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
