Question about Medion Televison & Video
Sky control code for tevion 40 inch lcd model 30180 tv
Need code for the sky remote to pair with thew tv so i can use the volume and change channel buttons on it, thanks
SOURCE: Tevion 19 LCD TV Model Number 1961HDT
eh, that should be 0871 663 1540
Posted on Jun 25, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SOURCE: Tevion LCD3210ID remote codes - Please Help
i cant get anything on my tevion television/dvd
Posted on Jun 14, 2009
  • 393 Answers
SOURCE: hi there i need code for sky remote to pair up to
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
Posted on Feb 28, 2010
SOURCE: need code
hi i have a baird or42bafhd tv and iv lost the book and need to no the specific features could you please help me
Posted on Mar 24, 2010
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
Hi there i need code for sky remote to pair up to samsung lcd tv model number LE40b652,have tried 0060 in the book but not working sky bloke said that there is a tv model number code
Feb 28, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Need an activation code for my sky+ remote to operate the volume on my samsung lcd tv le40s8.
switch to sky on tv and press interactive on sky remote then move down to sky customer service (select) once screen has loaded move down to programe your remote you will need model number and make of tv press select and then enter the make of tv by moving down list once found select and repeat for model then follow on screen instructions
Dec 11, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Apr 26, 2009 | Televison & Video
Volume not working on sky remote
You will need a code in order for the tv functions of you sky remote e.g volume to work.
Click here to find out what remote control version you have.
If you have a remote control was produced after 2002 or there is no sticker
click here to use Sky's code look up tool.
Most SKY+HD Remotes are produced after 2002
Mar 21, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
type in 0 0 6 0
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Pair sky+ remote to tv
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
Jan 10, 2009 | LG 42LG50 42 in. LCD HDTV
Configuring Sky remote
3. Press tv again
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Medion Televison & Video Experts
Raj Patel
ray gallant
Are you a Medion Televison and Video Expert? Answer questions, earn points and help others
