Question about Pool & Spa
I am not able to adjust the temperature on the freeze protection.
  • 5,089 Answers
Unknown which freeze control you have.
http://waterheatertimer.org/pdf/PF1102M-freeze-control-manual.pdf
Usually the adjustment range is small for pool timer controls since pipes are made of plastic.
You can buy thermostat controls and convert them to freeze controls and give yourself wider range of temperatures.
Cadet 72801 has range from 80 to 40 degrees, and turns ON when temperature rises above set point.
You can reverse operation so it turns on when temperature drops below set point by installing DPDT relay.
10 amp use Omron LY2-AC or 30 amp use 5X847 relay.
http://waterheatertimer.org/H230A.html
Posted on Oct 28, 2012
Temperature setting True tssu-60-16
if you tried to adjust the temperature and the cooler continues to freeze the food then replace the thermostat attached to the control knob. Thermostats fail in different ways
Link=> HERE
APPLIANCE 911
Jul 22, 2016 | True TSSU-60-16-ADA Stainless Steel...
My hydroquip cs6230-u pack on my hot tub shuts off for days and comes back on. None of the circuit breakers pop. The cold weather is coming and I don't want any pipes to freeze. I would also like to u
I do not know this unit so this is only a guess on my part.
I am not sure what you are by it shuts off for days. If it is hot that may also cause it to shut down but for less then an hour. The manual can be found by googling:
hydroquip cs6230-u pack manual
Several of the manuals show up. Be sure CGFI is OK.
This is what I found in the manual. Measure your water temperature it may be OK.
FREEZE PROTECTION - There are two(2) levels of freeze
protection integrated into the system.
1 - SMART WINTER MODE, this mode will activate any time the
temperature falls below 59BF. This mode will be active for a period
of 24-hours. In this mode, if a pump has not been activated in the
last 2 hours, the system will automatically turn it on for 1-minute
to prevent freezing. The "Filter Cycle" indicator will illuminate
while this mode is active.
2 - If the spa water temperature drops below 49BF, the heater &
pump will be activated until the water temperature reaches 50BF.
While freeze protection is active no other functions will be
possible.
Nov 28, 2014 | Cars & Trucks
Freeze protection temperature in wrong
go into menu then find freeze protect it will ask which auxillaries to be selected select with an x in front then set temp for freeze protect
Mar 19, 2014 | Pool & Spa
Freeze protection on when temperature is 80 degrees
Your air temperature sensor may be broken. Does the display show the correct current air temperature? You can go outside and put the system in service mode. That will shut the pump off. Then you can disconnect the air sensor and see if the pump acts right after putting it back into auto mode.
Mar 19, 2014 | Jandy Aqualink Rs4 One Touch Control...
Refrigerator become freezing
If the temperature control adjustment wont warm it up my guess is that someone has been on the system with gauges and the refrigerant charge is wrong. Make sure the temperature sensor is attached securely and properly placed. The refrigerant charge is critical and if it isn't weighed in by the ounce exactly it will freeze.
Temperature control measures coil temperature not cabinet temperature. Hope this helps and good luck.
Feb 25, 2014 | Beverage-Air DP93 Refrigerator
Refrigerator is too cold even when adjust the temperature
Too much freon? Or maybe you got the controls mixed up. My refrigerator used to freeze a gallon of milk over-night.
Nov 18, 2012 | GE Adora DSS25KSTSS Stainless Steel Side...
De Dietrich fridge freezer temperature
thermosyat in fridge posibly stuck
Aug 04, 2012 | De Dietrich Refrigerators
We have to reset daily A-7
Before calling service technician, open following link for troubleshooting resources including error codes, manual, links to bosch, phone number, :
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
A7 is outlet temperature sensor fault.
Temperature below freezing or above 210 degrees F
1) Check red wire connections at hot water temperature sensor. Clean terminals with an eraser. If badly corroded, replace sensor and wire harness. (See Fig. 63, page 46 in manual).
2) Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions. Any damage due to freezing conditions is not covered under warranty.
3) Clean inlet filter screen and clear any debris out of shower heads, faucet aerators and whole house filters.
4) In areas where water has a high mineral content, periodic descaling may be necessary.
Apr 17, 2011 | Bosch AquaStar 2400ES-NG
Pump continues to run constantly after freeze protection was engaged. The temperature is now over 70 degrees F but the pump will not turn off unless you flip the override switch on the outside of the...
The freeze protection thermostat has gone bad.
To confirm this, disconnect wiring from freeze control.
Freeze control can be purchased separately.
Search: Intermatic Freeze Protector
For example, Smarthome:
http://www.smarthome.com/42697/Intermatic-PF1102M-240V-Freeze-Protection-Control-Timer-Mechanism/p.aspx
I am familiar with wiring for Intermatic pool controls.
If you have problem, add a comment with exact model number or photo of product.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also if you re-post question another question at Fixya with exact model number, I will probably see it.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call
Feb 21, 2011 | Intermatic PF1202T - Pool-Spa Freeze...
My Rinnai heater which is installed on the outside wall of the house is starting and stopping every minute with no load on it.
I believe Rinnai uses a short run to prevent freezing. If it detects temperatures at or below freezing inside it, it will run to prevent damage to itself (trust me, I had an Omega with no freeze protection and it was destroyed in less than a week -- no fun) However, it doesn't seem that it should have to run that often. Does it have a temperature readout on it? If so, is it correct? You may have a defective temperature sensor.
Mar 06, 2010 | Tools & Hardware - Others
Pool & Spa Logo
80 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
