Question about Kenmore Kitchen Ranges
I have a Kenmore elite range 790.97473804. The front right burner has 3 heat elements. The light on the touch panel use to light up for each element. Please advise which part should I replace. Thank you, karen
fridgetech
  • 473 Answers
SOURCE: Owners Manual
You can get the use and care guide at http://www3.sears.com/.  The part # is 318200838 and cost is $2.99.  Looks like there is a video available also for $35.56 and that part # is 316124202.  Would appreciate a solved rating for the advice.
Posted on Oct 17, 2007
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
thaurfen
  • 623 Answers
SOURCE: replacing a radiant element on
try this site for manual
http://kitchen.manualsonline.com/
Posted on Aug 19, 2008
jsrock516
  • 5911 Answers
SOURCE: Dual cooking zone burner not working
Okay...what you have is a dual element with the 6 inch coil burned out. Yes, this is repairable, but unfortunately, since this is a dual element, it is sold as one assembly. The part number for a replacement is WB30T10044, and you can find it at repairclinic.com for about $90 (repairclinic item number 824238). I know it isn't cheap, but it beats having to pay for a service call, or buying a new appliance.
If you wish to repair this yourself, you can do so by following these steps:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
3.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the wire harness from the connector and follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the affected surface element. Take note of the numbered positions where the mounting screws are located and locations of the wires. You may want to write down the numbered positions and the wire color codes. HINT: A good digital camera can save you time if you have one. You will need to install the new element in the same manner.
d. Install new element (upside down). Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
e. Re-install the cook top back on the range and you are DONE.
NOTE: If your range does NOT have a disconnect plug on the wiring harness you will need to perform the repairs with the cooktop propped up, and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the element secure until you have it screwed back into place. Don't forget to remove the duct tape when completed. Once completed, lower the cook top and secure with screws.
I hope you find this information helpful. Let me know if you have require additional assistance.
Posted on Sep 09, 2008
  • 311 Answers
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Front right burner under stove top model 62960002603 only heats to LOW heat. It has a single, dual, triple mode setting and will not heat up to highest setting. HELP.
I looked up the model number you gave. It is a Kenmore range.The part number for that element is 7406P494-60. When you say it only heats to low, do you mean that only the center portion of the element lights up? Normally, when this occurs, it is an indication that the middle element and outer elements have a break. The problem could also be a faulty infinite switch(burner control). The part for that particular control is 7450P011-60. You will need a voltage/ohm meter to troubleshoot further. This can be a very INVOLVED repair attempt. I recommend, that if you're not comfortable disassembling your unit, call for service--this can absolutely be a tricky diagnosis and much care is needed to not damage the glass cooktop when checking the element. I hope I helped you.
Aug 31, 2015 | Kitchen Ranges
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Kenmore c970-440935. Why does one element overheat?
Kenmore Elite C970 440935 Replace heating element range
www.fixya.com > ... > Ovens > Kenmore > Kenmore Elite C970 440935
Kenmore Elite C970 440935, replace heating element range related issues. Get free help, solutions & advice from top Kenmore experts. ... Kenmore 40494 / 40495 / 40499 Electric Single Oven. 793 Questions ..
Aug 05, 2015 | Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Kenmore 790.9622 electric range - front right inner burner not heating
You have to use a voltmeter to make sure the element is getting voltage, if it is, then replace the element
Jun 10, 2009 | Kenmore 96222 / 96224 / 96229 Electric...
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
Nov 28, 2008 | Kenmore Kitchen Ranges
Problem with range
the sensor not working or u had a electric problem
Aug 25, 2008 | Kitchen Ranges
Smooth Top doesn't cool down ????
does the lindcator light remain on nall burners cold to touch?, or is the element actuall on low?? if just the hot surface indicatoris on and elelmnts are cold to touch you hae a bad element. if the elemnt wont shout off the problem is in the switch. i would ck with manufacture depending on age you may have a part warr for 5 yrs on the elemnt itself
Mar 12, 2008 | Kenmore 92420 / 92421 / 92422 / 92424 /...
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
42 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
