Question about Plumbing
I have a Blanco 440631 Master Gourmet kitchen faucet. What size allen wrench do I need to remove the handle.
4 Suggested Answers
  • 4 Answers
SOURCE: Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Posted on Jun 13, 2009
  • 349 Answers
SOURCE: remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Posted on Jun 13, 2010
  • 1015 Answers
SOURCE: Removing the handle on Meon single handle pull out
Try using a 7/64. I think that is the right size.Thank you.
Posted on Aug 29, 2011
What size allen wrench do I need to tighten a moen (annabelle) single handle kitchen faucet?
google manufacture or go topumbing supplier and they should help you
Mar 02, 2015 | Moen Plumbing
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
I want to change the cartridge but am lost as to how the faucet comes apart.
From www.hamatusa.com
Turn off water at supply line. Turn and remove top ring. Remove handle. Remove top half of body of faucet. Remove diverter (using large screwdriver) and replace. Replace body handle and ring.
Let me know if this works or not.
Gary
Dec 16, 2010 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Remove water saver device from Blanco Grace kitchen faucet
Jun 12, 2010 | Blanco 157-052-ST Grace Single Handle...
We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
May 30, 2009 | Blanco Classic Single Handle Faucet with...
Plumbing Logo
80 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
