Question about Toshiba 40E220U 40" Class LCD TV
What size rear mounting screws for a toshiba 40E220U
Need the size of screw required for rear mount
  • jamesv306
    jamesv306 Oct 27, 2012
    I know they need to be M6 but how long?
4 Suggested Answers
SOURCE: tried mounting bracket m8 screws and then went to
They're 6MM
Posted on Dec 28, 2011
SOURCE: Can't find screw size to
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Posted on Jan 14, 2011
SD Tech
  • 14553 Answers
SOURCE: JLC37BC3000
best way is to call whoever made the set for length, thread type and number of bolts.
Posted on May 14, 2012
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
REAR SCREW SIZE TO HANG TV MOUNT
try your local hardware store, use a pencil as a guide to help size the bolt needed, you might need to buy a few different sizes, but make sure it's the right tread ! you can return the bolts not used, you need 4 bolts total and there mostly metric.and a certain length DO not use long bolts !
If hanging the mount on the wall, once again ask your local hardware store guy for assistance, these tv's are heavy and need to be mounted properly, and can kill if they fall. so do it right !
Sep 03, 2015 | Hisense 55K22DG 55-inch 1080p 120Hz MHL &...
What size screws are required for wall mount on tv ?
I did not find that listed in the owners manual, you will need to contact the manufacturer as to the mfr recommendation of proper mounting screws.
Oct 16, 2014 | Mintek DTV-265-D 26 in. LCD TV
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
Size of screws for sanyo 55 inch LCD to mount base to tv
After repeated trips to the hardware store and more calls to Sanyo and conversations with supervisors...depending on the year of the TV....2011 requires M5x16. The next year model requires the same size that bolt to the back of the TV. I had to elevate my request for the size of the base screw of the 2011 model all the way to engineering before I got the answer. They changed the configuration in the 2012 and later models.
Jan 02, 2014 | Sanyo Dp55441 TV
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
How do i change the brake light on jeep liberty 2006?
1) You will need to open the rear swing door.
2) On the inside jam there are two torx headed screws (T-15's if I remember correctly).
3) Unscrew the two torx screws.
4) The light is now held by two mounting tabs (small spherical headed plastic sets that go through a rubber grommet).
5) You will need to pry the light casing off (easy pressure with a good size flat head screw driver will do the trick).
6) The light bulbs are twist mount settings inside the light casing.
7) Twist out the mount setting, change the bulbs, and reset the light mountings.
8) To put the light casing push the light casing back on and put in the screws. Everything else will work in reverse when it comes to assembling the whole unit.
2006 Jeep Liberty Replacement Light Bulb Sizes
Low Beam Headlamp Bulb Size: 9007
High Beam Headlamp Bulb Size: 9007
Parking Light Bulb Size: 2825 or 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3757ALL
Tail Light Bulb Size: 3157
Stop Light Bulb Size: 3157
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: 9145 or H3-55W
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 3157
Front Side Marker Light Bulb Size: 168
Ash Tray Light Bulb Size: 161
Map Light Bulb Size: 578
Dome Light Bulb Size: 578
Step/Courtesy Light Bulb Size: 906
Trunk/Cargo Area Light Bulb Size: 578
Thank you for using fixya, and good luck
May 08, 2010 | 2006 Jeep Liberty
Toshiba 40E220U 40" Class LCD TV Logo
361 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
