Question about Electrical Supplies
Have a diesel ETQ generator DG6LN that runs 5 minutes and then oil light goes on and shuts itself off, It has enough oil)
Shuts off due to oil but has enough oil.
SOURCE: generator runs for a short time
does your generator have a metel tank? If it does it probley has rust in the shut off valve under the tank.
Posted on Nov 30, 2008
  • 11 Answers
SOURCE: diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Posted on Mar 21, 2009
farfield
  • 462 Answers
SOURCE: Generator won't run
DId you change the oil filter when you changed the oil I am assuming it has one.
If it has a filter some of them have a check valve in side and this valve may not be operating properly.Also you might try rolling it over a few times with the pressure sensor removed and see if oil spurts out the opening. If so then the problem may be the oil pump not building up oil pressure, or the motor may have a board looking for the oil pressure sensor to close (or open depending on how its engineered) and the sensor board is not working properly or not grounded good. Try cleaning the battery cables just in case (assuming it ahs a battery).
Posted on May 08, 2009
  • 583 Answers
SOURCE: Coleman Powermate 6250 stops after 5-8 minutes of running
the carby needs to be cleaned out properly the jets blown out with air.when you intendto stop useing for any length of time swich the fuel off and let itstop by running out of gas or drain the carby before storage ,as fuel evaporates and the additives dont they build upafter a while and start to block the jets make sure motor is level,oil cutoutcan be fooled if not level ,disconectwire if worried about that bing the problem
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: I have a em5000a 2000 model honda generator it
It sounds like an low oil censer. make sure the oil level is at the full line.
Posted on Aug 25, 2009
check whether the oil pressure sensor is working properly,display shows the correct pressure or not,otherwise replace or clean the pressure transmitter
Oct 11, 2017 | Diesel Electrical Supplies
Why does my generator not produce enough energy automatically only manually?
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/
Generator Guru
Aug 31, 2015 | Eastern Tools & Equipment ETQ DG6LN 5,500...
Where can I find a service center in Pasadena, TX or Houston, TX????
YOU CAN FIND OUT ON THE YP (YELLOW PAGES) LOCALLY AND ON THE INTERNET YP.COM
Jun 17, 2015 | Northstar ETQ DG6LE Portable Generator...
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
How do i start mY GENERATOR
You can buy a new ignition switch either keyless or one with a new key. They sell cheap ones at autozone if you know something about electrical it's really easy to install yourself.
Jun 18, 2014 | Eastern Tools & Equipment ETQ DG6LN 5500...
Generator runs good but when light is plugged in it lights up then goes back off after 15 seconds then comes back on.
Check the rotor slip rings in the generator end for tarnish, and also the brushes. It would not hurt to check the capacitor also in the alternator. If the unit has sat for a long period of time, let it run for a long period, this will help build the rotor magnetism back up (with nothing plugged in) if it still does the same thing, then have the rotor flashed, this is done by applying a correctly polarized battery voltage to the rotor for approx 3 seconds. It may have enough residual left thus powering your lights then it bleeeds off. Let it run for a while no load and it may increase
Nov 08, 2013 | Eastern Tools & Equipment ETQ Tg32p12ca...
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
Electrical Supplies Logo
55 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
