Question about Philips 50PF9731D/37 50 in. Plasma Television
2007 50' Philips plasma, have sound but lost picture
I still have sound, but my screen suddenly went to verticals lines, then I lost the picture all together. The screen is black but the sound in tact.
SOURCE: has sound but no picture
Is known problem at servicepoint if there is no white/yellow light present/visible at the (lower) backside of the flattv. This is indicatorlight of a certain condensator. If there is no light than servicepoint needs to instal new condensator. good luck
Posted on Feb 20, 2008
jdbouncer
  • 72 Answers
SOURCE: philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Posted on Apr 29, 2008
  • 22 Answers
SOURCE: Vertical lines down center of Plasma TV
If it was just a vertical black line, i could definitely solve your problem.  However, i would still perform the following fix if i was you.  It worked for me on my gateway plasma.  Go to the following link and read carefully and follow closely!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
ST
Posted on Apr 28, 2009
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
SOURCE: 42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Posted on Dec 08, 2009
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Vertical Lines
Hi I can try soling your problems
Feb 22, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Lost half of picture
This can be on the matrix drive board, or the display assembly itself. It is possible to also have a defect in the address decoding area that will cause this.
The procedure is to swap out the suspect boards to determine where the fault is, leave the working boards in the set, and then follow up any necessary calibrations that are necessary.
Jerry G.
May 24, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
Bright line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Dec 05, 2007 | Philips 19PR19 19" TV
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
Philips 50PF9731D/37 50 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
