Question about Electrolux Eureka Airspeed AS1001A Upright Vacuum Cleaner - 12 A - Bagless
I am looking for a wiring diagram for a Eureka AS1001A upright vacuum. Any help would be appreciated.
I am replacing the motor and didn't notice that there were 4 leads on the motor when I dissasembled (2 leads on each side of the windings, 180 degrees from each other).
Hoover electrical diagram
Hi David. We recommend you take your cleaner to a Hoover authorized service center to have the motor on your C1810010 repaired or replaced. Follow the link below to find a service center nearest you. Thanks!
Service Center Locator
Aug 01, 2014 | Hoover Commerical C1810-010 Conquest...
How to open the casing - kenmore intuition 116.312
Similar to your Kenmore upright is the canister. Here is a video clip by another with similar issue of trying to open the darn thing up. I hope this gets you closer to solving your problem with the vacuum. If not with a few Kenmore vacuum "search" in youtube I think you will find what you need.
PEACE
https://www.youtube.com/watch?v=s0aaoPzCAcM Kenmore 116 26212690 vacuum cleaner disassembly to motor
Jun 03, 2014 | Kenmore Intuition 31810 Upright Bagged...
Why won't my Hoover Platinum turn on?
Check and see if there is a reset button for the vacuum head this trips sometime to protect the head motor. Also if the roller heads bind they can snap the belt if it is belt driven. If it is direct drive then I would look for the trip or reset button.
May 14, 2014 | Hoover Platinum Lightweight Upright Vacuum...
Replacement Parts
Sorry we do not have parts here or parts books,.
Jul 06, 2017 | Electrolux Eureka Optima 437AZ Lightweight...
Bearing on brush is hard to turn and smells like it's burning
bearing hard to move will put strain on the belt and burn it. the bearing is easily removable pull it off, sometimes its just a good clean it will need, if will not come off tape it off. remove the muck build up and give the bearing a good soak in some wd40 or oil and wipe off and check for good movement then replace the belt. as it will snap more easy now it has been heated up.
Mar 15, 2014 | Eureka The Boss Upright Vacuum Cleaner
The piece on the bottom of the vacumn that controls rug height will not work
I had to use pliars to change the level. I only used that vac three times and I got rid of it. It cut off on me and never restarted. Sorry!!
Mar 05, 2014 | Eureka AirSpeed Bagless Upright Vacuum,...
Eureka abs AS1050 will not power on?
There is a wire in the motor housing that comes loose plug it back up and it should start
Nov 30, 2013 | Eureka AS1104A Bagless Upright Pet Vacuum...
Uh70600
Take the filters out and turn the vacuum on, if it will stay running without the filters in it you need to replace the filters. Filters should be replaced every few months. Clogged filters still pick up some dirt but miss a lot plus it causes the motor to run hot which will cause damage to the motor reducing it's life.
Nov 20, 2013 | Hoover UH70600 WindTunnel MAX Bagless...
My eureka vacuum stopped working.
Need more information. Does the motor run, does the brush turn, does it have suction?
Aug 03, 2013 | Eureka 4870 Boss SmartVac Upright Vacuum -...
Hoover wind tunnel can the dirt cup be washed it smells horrible and I am moving to new house and dont want to stink up the house with this vacuum I hate to go out and biuy a new one as this one is on
yes you can wash the dirt container in worm soapy water,rinse off and make sure it's absolutely dry before you use it again.this link is for the manual if you need it. good luk in your new home.***
http://hoover.com/file/570/
Sep 21, 2012 | Hoover WindTunnel Rewind T-Series UH70120...
Electrolux Eureka Airspeed AS1001A Upright Vacuum Cleaner - 12 A - Bagless Logo
82 people viewed this question
Top Electrolux Air Purifiers Experts
Richard Lane
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
