Question about SanDisk Sansa e250 MP3 Player
Pc wont recognize my sansa fuze mp3 player 2gb
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 04, 2009
Sansa e200 wont recognize 8GB microSD
The Sansa e200 series machines work with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use microSD cards, which are 2GB and smaller.
Later model Sansa such as the Fuze will work with microSDHC cards, but not the e200. Sorry if this wasn't the answer you wanted to see, but that's the way it is.
Aug 20, 2011 | SanDisk Sansa e250 MP3 Player
Sansa Fuze MP3 Player with 2GB* Hard Drive - Black: how to load a video from my PC to sansa sandisk f...
You need to use the supplied Sansa Media Convertero to convert videos (and photos) to a format the Sansa can handle.
May 16, 2010 | SanDisk Sansa Fuze MP3 Player
My Sansa Fuze 4gb wont turn on and isnt being recognized by my computer, iv also tried to soft reset it many times , nothing seems to work.. help plz..
I've had the same problem with my Sansa Fuze 2GB. It's pretty frustrating, but in order to get it to work, I let it sit without touching it or doing anything with it for a few days. For 2-5 days, do not turn on your Sansa Fuze. After the amount of time has passed, try the soft reset again.
Apr 22, 2010 | SanDisk Sansa Fuze MP3 Player
My device does not recognize a 2gb micro sd I install. Is there a procedure for installing this?
Glad to have been of help.
Cards bigger than 2GB won't work. The Sansa works with microSD cards. Cards bigger than 2GB are actually microSDHC (the HC stands for High Capacity) and use a different protocol. Newer Sansas such as the Fuze will use them but the e-series won't.
Apr 06, 2010 | SanDisk Sansa E280 MP3 Player
I plug my player to pc and pc wont recognize player i also plug diffrent model in pc , pc recognizes this one what do i do
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just in case.
Hope this helps!
Oct 30, 2009 | SanDisk Sansa Fuze MP3 Player
2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Aug 27, 2009 | SanDisk Sansa Fuze MP3 Player
My computer doesn't recognize my sansa fuze
On your Sansa Go to "Settings" then "System Settings" then "USB Mode," change it to MSC, now try connecting it. If that doesn't work try the other modes just in case.
Hope this helps!
Jun 03, 2009 | SanDisk Sansa Fuze MP3 Player
Need manual for sansa fuze 2gb mp3
here's the sansa web sight with the sansa manual that your looking for http://www.sansa.com/support/sansa_fuze/faqs
Mar 14, 2009 | SanDisk Sansa Fuze MP3 Player
How long should sansa fuze 2gb be charging?
Maybe your laptop is not fullu charged itself go charge it with the mp3 while its off and see if that works
Jan 06, 2009 | SanDisk Sansa Fuze MP3 Player
SanDisk Sansa e250 MP3 Player Logo
74 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
