Question about Dryers
Uneven cieling solution please - Dryers
  • 5,089 Answers
Use laser level to find level line around room.
Figure out how you are going to change ceiling lights as part of any plan.
1) Put furring strips across room 16" on center.
Use shims or spacers under furring strip at each nailing point to keep level.
Re-install ceiling electrical boxes to match new ceiling height.
Install new sheetrock.
2) Install suspended ceiling grid.
The cross grid is held with wires attached to old ceiling.
Plan for electric lighting by installing can light fixtures or drop in 2'x2' or 2'x4' fluorescent lights.
3) Float smooth, and prime ceiling.
Have artist paint cloud scene on ceiling to disguise unevenness.
Posted on Oct 28, 2012
My machine is stitching unevenly. what can I do.?
Please expand on "stitching unevenly." Is the thread looping above or under the fabric, are the stitches uneven, is it skipping stitches????
First thing to always try is a brand-new needle.
All About Needles
Apr 07, 2016 | Sewing Machines
Cieling for toyota corlla 2005
cieling?
sealing or Ceiling? ask a full question
loke
how do I X
or where can I buy Z
or ??? like that , question form.
Jan 19, 2014 | 2005 Toyota Corolla
The fan doesnt work
and nothing is there a fan motor available.
Did you mean " and nowheres is their a fan motor available"???
THat leaves you with 4 options.
1. prehaps the switch to the fan is not giving the fan any electricity when you turn the switch 'on'
2. prehaps there is a bad wiring connection to the fan and the repair is as simple as fixing the supply wiring.
You need to make sure that the fan is getting electricity before saying ,I have a bad motor. You could have a bad on/off switch or wiring to the switch or to the fan.
if you do have electricity going into the fan motor.
1. disassemble , repair, and reassemble the fan motor. That assumes that you can get repair parts and already know how to fix cieling fan motors or can even find a ceiling fan repairman.
I think cieling fan repair is a decesed industry[the job died because of lack of customers] like tv repair and microwave repaair,dead professions.
Many things from china are made as one shots[if they done work on the first shot,they never will because there are no replacement parts available in the usa. You have to fly to china to buy parts.
2. buy a new cieling fan from amazon.com
Mar 02, 2013 | Hampton Bay 24002 Ceiling Fan
Give me a name as combination for Ciel
I'm assuming you want the meaning of the name Ciel? The meaning of the name Ciel is from heaven, heavenly. It is a female name of Latin origins.
Please be more specific of what your question is or re-word it if I'm mistaken.
Mar 03, 2011 | ArcMedia ABC of Baby Names
Can u give me a baby boy name stars in letter M and G?
MeGan.
MaGog.
GaMmal.
GeMMel.
GiMli.
MiGa.
MoGli.
MuGGins.
GoMer.
Oct 24, 2010 | ArcMedia ABC of Baby Names
I have a hampton bay ac 552 cieling fan and the owner cut the wires,what wires goes to the fan and what goes to the lig hts.,black,white are coming from cieling in the fan above lighting wires...
Hampton Bay makes fans for HomeDepot. I would check with them or call 1(800) 654-0688 to try to get the information from the fan manufacturer. You need to find the UPC number which is located on a label on the top of the fan(body). I had a hard time making the numbers, but gat a camera and took a close up picture, but your is probably not mounted. The HomeDepot will help you find out the maker of your fan.(they have many makers so it is important to have the UPC no.)
Aug 02, 2010 | Hampton Bay Dryers
No instructions for my 52" Aloha Housewares fan?
i have installed these so i can walk you through it. first if it has already been wired (properly). a wall switch or string will operate it. i suspect you should begin assembly on the floor. then acquire a sufficiently tall ladder. then hang it from the cieling. then connect the wires. then secure it to the cieling. FINITO
Sep 07, 2009 | Aloha Housewares (93645) Ceiling Fan
How do I get my hampton bay antigua fan down from the ceiling
first you will need a ladder and a screwdriver/phillips a couple wire nuts or electrical tape.at the "top" of the fan you will see a bowl shaped cover it will have usually no more than two screws in it..loosen or remove those screws to access the fan hanger inside.once you get that far inside you will see several wires .undo each wire seperatly and cover with a wire nut or electrical tape(please make sure your power is off to that circuit) once you have unhooked all the wires from the fan and secured them out of the way. lift the fan out of the hanger itself (sometimes it is easier to remove each blade from the motor housing before removing the fan from its hanger ) those screws can be found at the base of each blade on the motor housing..If you are moving or adding a cieling light be sure to remove both parts of the fan hanger..the second part will still be attached to the cieling..usually two screws holding it into place..if just replaacing the fan,,you can sometimes leave the second part there and hang the new fan with it..
Jul 30, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Optoma projecter
It is most likely getting too hot.
Make sure all the fans are clean. Make sure the projector is not mounted too close to the cieling. This may block vents in the housing.
If you have to, you may need to mount a small fan near the projector to blow into the vents. Make sure it blows in the right direction. You don't want it working against the fans inside the projector.
Just for a test, unmount the projector and run it on a table. This should tell you if the mount on the ceiling is causing the problem.
Aug 29, 2008 | Optoma H30 Multimedia Projector
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Dryers Logo
124 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
