Question about Redmax Ebz5100 Back Pack Power Blower (Redmax)
If there is no compression can this be fixed
Wont start dont think there any copression
    Sergeant:
    Champion:
  • 278 Answers
Thinking is not a fact. pull plug wire off, pull starter rope. do you have pulses of resistance? Yes, =compression good enough. No, = expensive repairs(new head and/or piston)
Posted on Oct 29, 2012
No compression, decompression jammed
Valves could be sticking closed or open causing (good or bad compression) that or de-com-lever if faulty somehow.. And you need to do a compression test
Oct 04, 2014 | 2004 Yamaha WR 450 F
2005 magnum v6 overheated. after cooling down it wont start acts like no copression
pull spark plugs and do a compression test on each cylinder you may have a blown head gasket or cracked head
Aug 10, 2013 | 2005 Dodge Magnum
Why no compresson
could be a valve problem or a ring problem try a teaspoon of oil in the cylinder and check compression again if no change sounds like a valve problem
Jun 06, 2013 | Tecumseh Garden
No compression on 2003 saab 9-3
have you checked the timing belt?? this would cause there to be no compression it may also have bent some valves
May 08, 2013 | 2003 Saab 9-3
1989 FORD FESTIVA OVER-HEATED, STOPPED RUNNING, NOW WONT START
When a vehicle doesnt start,anything tyhat looks out of place we think that anything out of place if the problem. You are a 1.3 If you overheated you may have blown the head gasket,you dont necessary have to have oil and water mixed, you can be loosing compression going into the radiator.Yes the timing could of slipped,but that rare. When you are cranking it and it sounds like it wants to start it loosing compression somewhere.And it wont start.The heads blown
Mar 10, 2012 | 1989 Ford Festiva
Got spark starting fluid wont turn it over
Check to make sure you have compression in the cylinder, place you thumb over the empty spark plug hole and pull the cord, if it blows hard against your thumb then it has good compression, if it has spark and compression it will start unless it is not getting fuel. Be careful when using starting fluid as to much of it can damage the engine. If there is no pressure against your thumb then there is a copression problem where the piston rings maybe bad or something is stuck open in the intake or exhaust.
Mar 17, 2011 | Garden
Why does it not want to start sometimes ive fixed almost every possible problem?
You need three things to start an engine. A combustible fuel, air, a means of igniting the compressed fuel and compression. Which one are we missing? We have air and copression, right? Do we have spark? Are we getting fuel? The coolant temp sensorsets up the fuel for cold starts and backs off as the intake air temp and coolant temp rises. have you chk'd and cleaned the Maf sensor? Use CRC electrical cleaner to wash it clean. It's in a metal section iof the intake ducting. do not rub or brush it and no compressed air. See what does for you Get the cleaner at the oparts store.. One more thing . Use the spray to wash off the crank position sensor. Remove the connector and wash it dow with the spray. Make sure the sensor is secure and reconnect it. Now. Good luck my friend. If this doesn't work, I expect it to work, We have a couple of options left..
Oct 15, 2009 | 1995 Honda Accord
87 cbx250 not firing
you probally need to retime it find top dead center on copression stroke and aline your cam then put your chain on that shoul do it did you take the cam chain off or loosen your tensener? if so you need to re time it
Jun 20, 2009 | 1987 Honda CBX 250
Need copression specs
The compression should be 8.5:1 on the 3L V6
May 18, 2009 | 1998 Mazda MPV
2000 audi a4 2.8 was hit in the front change the bumper ,radiator
Sounds to me like your timing belt jumped on bank 1.
Dec 11, 2008 | 1998 Audi A4
Redmax Ebz5100 Back Pack Power Blower (Redmax) Logo
189 people viewed this question
Top Redmax Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Redmax Garden Expert? Answer questions, earn points and help others
