Question about AOC 42 Envision L42H961 1080p Widescreen LCD HDTV - 16:9 25000:1
The yellow colors on my tv are too bright
One day I turned on my tv and the colors were way off. It seems like the yellow colors are too bright. Skin tones are are like a bright yellow instead of "white." I have tried adjusting the colors on the tv but it doesn't help. Is this an affordable repair or will I be better off buying a new tv?
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
I have olive skin and dark circles under my eyes. I'm using the 1022-05 brightener but it seems too light. I wear a foundation by Bobbi Brown that is a beige color... Thank you.
From my own experience, the darker you skin color the more you want to avoid anything with a purplish hue around your eyes. Regardless of how bright the color is, it will darken your skin. I have found that instead of using a concealer for under my eyes using a different shade of foundation (one that is one to two shades lighter) is just as effective, if not more so. Be careful, when mixing two different foundations, blending well is the key.
If you wish to stick with concealer I would try to Sally Hansen Light if you wish to remain with that brand. Try concealers that have just a hint of pink or yellow to compliment your skin while brightening.
Jun 05, 2011 | Sally Hansen Natural Beauty Fast Fix...
My Samsung DLP 5663W was making the loud humming noise. Picture was just fine, but the noise was loud. I checked both fans which seemed to be fine, so I ordered the replacement color wheel. When I replaced...
On the metal box where the two cables from the color wheel plugged look for a tiny rectangular opening in the metal shield---there is a tiny jumper plug there, remove it carefully with a tiny pair of needle nose pliers.
One of the things they do not tell you when you replace the color wheel, it is somewhat different than the original one.
SD TECH
May 06, 2011 | Samsung DLP HL-P5663W 56" TV
I am having trouble adjusting my colors for my kp 53s25 there seems to be a lot of yellow how can i solve this?
This TV has had a long life. Your picture is looking more yellow these days because the Blue picture tube is wearing out. Not saying the Green and Red tub are much better, but Blue tube is a major player in the picture brightness and white balance (the color of white which the TV reproduces). The cost involved wouldn't be justified. You should enjoy the balance of the TVs life; when it's time comes... have the new TV delivered and ask them recycle this one. Best wishes.
Apr 26, 2010 | Sony KP-53S25 53" Rear Projection...
My hp monitor's colors are messed up.
Did you already try it on another PC?
Try new VGA cable?
Otherwise you may have to open it up and look inside for failed components.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | HP Vs17 17" LCD Flat Panel Monitor
I have a toshiba 56hm195, colors skin tones are washed out, reds
I'm having the same problem; have you found any solutions yet?
Dec 22, 2009 | Toshiba 56HM195 56" Projection HDTV
Sony klv-40w400a has a strange green tone
Okay would love to help you with this issue but most good reults if you choose to chat with me! The prblem with these color changes are most have to due with the aparatus your connecting to the Tv and not the Tv itself. But if you got it on all things its a decoder issue have the tech check the decoder. You will be glad you did.
Please rate.
Aug 21, 2009 | Sony KDL-32S3000 32 in. LCD Television
We have blue ghosts with brilliant colors
This sounds like the most common thing that fails on projection TV's, regardless of the brand. The convergence circuit has two STK392-110 IC chips mounted on heat sinks to drive the convergence yokes. They typically last anywhere from 5-10 years, then they fail. A more robust part is now available (STK392-150) as a direct drop-in replacement. My shop has installed these IC's in hundreds of projection sets and had fewer than 1% of them come back with repeat failures. Also check the following low-ohm feedback resistors to make sure they did not go out of tolerance:
  • RK42: 2.7
  • RK46: 2.2
  • RK58: 3.9
  • RK52: 3.3
  • RK50: 3.3
  • RK54: 2.2
Jan 25, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
Colors are messed up
the deguasser in your tv may not be working right..or the magnets in the corner of your tv has moved....it can be manually deguassed but a tv shop would have to do it..
Jun 28, 2008 | Sylvania 6427TE 27" TV
AOC 42 Envision L42H961 1080p Widescreen LCD HDTV - 16:9 25000:1 Logo
57 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
