Question about Elna Quilter's Dream 6003Q
Vintage elna condenser--how to replace?
I have an Elna #1 sewing machine, the 'grasshopper' model, which runs fine but has a condenser/capacitor which is leaking. I don't think I can get the exact part to replace it with, but I'm wondering if I can replace it with the modern equivalent, and if so, how would I go about finding one?
  • 3 Answers
I just purchased a fairly tidy Elna 'Grasshopper' sewing machine with the same leaking capacitor problem. I carefully removed the capacitor for examination. It is actually three capacitors in one - no chance of a direct modern replacement, but anyone with those three capacitors, a couple bits of insulated wire, and a small soldering iron should be able to shoehorn them into the same space. There is a circuit diagram printed on the side of the original capacitor, showing one 0,2 micro-Farad capacitor between the two mains power buses (the two wires from the top of the original capacitor which are soldered to the top of the two outer brass bars where all the wires attach), and following on from each of those a 0,0025 micro-Farad capacitor (so, two of those), the other side of both of those joined together and going to the chassis - representing the one cable from bottom of the original capacitor, which is screwed down. Easier than it sounds - I just have to find those capacitors. They must be NON-polarised capacitors, rated for 250 Volts, and I plan to use radial (rather than axial) style, aluminium type ones - very common. From what I can gather, I believe they are needed for that lovely little motor to run properly - to have torque ('oomph') at start-up - never mind the radio interference.
Posted on Jul 28, 2011
  • Paul Howell
    Paul Howell Jul 28, 2011
    I agree with blaiddwyn. A condenser is one thing, a capacitor is another. You need to replace capacitors as blaiddwyn described.
  • Wolf Thandoy
    Wolf Thandoy Jul 29, 2011
    Hi Zenqi - You are too kind. Condensers in the USA (and France, at least, as condensateurs), capacitors in the UK (and Empire, no doubt) - the same thing, in principle, are they not? Having spent a good long while searching for replacement pieces (and taking note of the ridiculously small capacitance ratings), I am today of the opinion that you were correct, and suppression of radio frequency interference (RFI) was the only and true purpose of that goopy old paper can. So I've come back to apologise to you and more importantly correct myself. I still have to prop-start the hand wheel to get the motor off the line, but with no near neighbours, who's to complain if there's a bit of static? Now, if only I can reprogram my muscle memory to think the knee control is a throttle and not a presser foot lift, I might lay some stitches down. I do still intend to cobble together a replacement (to filter the DC from the AC, if I read it rightly), but won't fear using the machine meanwhile - with the leaky one neatly removed, of course. One could simply clip its two top wires close to the solder and pull the cables back a bit, with no soldering iron to hand. And thanks again - you're a star.
  • 208 Answers
Lots of these old machines had condensers to prevent radio and TV interference (static on the radio when using the sewing machine). Depending on which one it is, you might be able to cut it out and bypass it.
Posted on Jun 19, 2009
  • 2 more comments
  • Wolf Thandoy
    Wolf Thandoy Jul 28, 2011
    I just purchased a fairly tidy Elna 'Grasshopper' sewing machine with the same leaking capacitor problem. I carefully removed the capacitor for examination. It is actually three capacitors in one - no chance of a direct modern replacement, but anyone with those three capacitors, a couple bits of insulated wire, and a small soldering iron should be able to shoehorn them into the same space. There is a circuit diagram printed on the side of the original capacitor, showing one 0,2 micro-Farad capacitor between the two mains power buses (the two wires from the top of the original capacitor which are soldered to the top of the two outer brass bars where all the wires attach), and following on from each of those a 0,0025 micro-Farad capacitor (so, two of those), the other side of both of those joined together and going to the chassis - representing the one cable from bottom of the original capacitor, which is screwed down. Easier than it sounds - I just have to find those capacitors. They must be NON-polarised capacitors, and I plan to use radial (rather than axial) style, aluminium type ones - very common. From what I can gather, I believe they are needed for that lovely little motor to run properly - to have torque ('oomph') at start-up - never mind the radio interference.
  • Wolf Thandoy
    Important: In the case of my machine (built in October of 1951), all those capacitors are 250 Volt. Probably this is true for all those models.
  • shannon
    shannon Dec 08, 2013
    Well, I had the same problem with the condenser, the machine smoked and the motor was sluggish, I removed the condenser and the machine runs without it! No more smoking and the motor is faster too.
  • shannon
    My husband did solder the two leads together and the machine kept flipping the breaker, so he unsoldered it, covered the ends in electrical tape and the machine is great!
I need a 220v cord for an Elna Grasshopper and the spool holder. Where do I find?
Wow, that's getting to be a very old model now. Being 220 Volts tells me you are not in USA. Have you tried the Elna office in your country first? start with www.Elna.com and choose your country to locate the head office and give them a call. If the parts are still available, they should know.
Apr 20, 2014 | Elna Quilter's Dream 6003Q
Can you drop the feed dogs with an Elna Grasshopper?
No the grasshopper has fixed feed dogs. There was a feed dog cover plate when the machine came out. This part is no longer available
Apr 06, 2014 | Elna 2007 Mechanical Sewing Machine
Can a genic foot pedal be used on an Elna Super?
Take a look at the side plate on your Elna and look for a two digit code, this is the model number.
I'm assuming that you are in the USA on 110 Voltage. If so visit this website,
http://www.sewingpartsonline.com/elna-sewing-machine-parts-model-list.aspx and choose your model. They sell replacement foot pedals, just check the profile of the plug that goes into your machine.
The other option is contact the Elna guru, www.whitesewingcenter.com, he stocks a wide range of swiss Elna parts and may have the original foot control second hand.
If you are on 240 voltage then you'll need to source it from a country that has the same voltage like UK, Australia or NZ.
Lastly, you may wish to join the Yahoo group called "ELna Heirlooms" this user group of Elna owners is really helpful and shares lots of their love and knowledge for these beautifully made Swiss machines. Many of them have even earlier models than yours such as the Green Grasshopper, the first Elna machine.
Dec 19, 2011 | Elna 2007 Mechanical Sewing Machine
Looking for an instruction manual for a 30 year old elna sewing machine, not sure about the model number
Hi Mary,
check out the machine info plate, it is usually near the power inlet on the side below the flywheel. Hopefully if it is legible there will be a 2 digit number which is the Elna model. There is also the very early model called "1" or Grasshopper, this is a bright green beauty with a knee control. And a model after that with a six digit model code.
If you are in the USA, you may want to contact the White Sewing Center, www.whitesewingcenter.com, he is the guru for all things early Swiss Elna including stocks of very old spares and manuals.
My other suggestion is that you join the Yahoo newsgroup called Elna Heirlooms, this is a fantastic group of vintage Elna owners who share lots of information and are very knowledgeable. Just go to www.yahoo.com, join up, then go to Groups and search for "Elna Heirlooms". The moderator will need to approve you as a member initially, then you can peruse messages and check out the files, this is such a great source of information on these beautifully engineered machines.
Nov 06, 2011 | Elna 2007 Mechanical Sewing Machine
Elna 1 sewing machine (Grasshopper): Does anyone have the owner manual in English or Spanish? I would appreciate it so much. Thanks Susana susana.2007@yahoo.com.ar
I located one here but it's not free http://www.tradebit.com/tagworld.php/elna+1 At this point I haven't seen any others but there might be some on the net. New machines often have downloadable manuals but since that machine was made in 1940... BTW I had one of those and other elnas. It's a good machine...
Mar 08, 2011 | Elna Sewing Machines
I just got an Elna "Grasshopper" The manual is in
Hello
Would be it possible that you make me a copy in file pdf of your instructions for use in French?
Thanking you in advance for your help
Hughes PATOU
hughes037@aol.com
Nov 19, 2010 | Elna Heirloom Edition 6005
Extra discs for an vintage Elna Supermatic plus pressor feet.
Try the usual eBay route, but also approach any Sewing Repair shop as they often acquire odd bits from old machines....We had 9 disks for a lady with an Elna SU only last week, all from a machine traded 2 years ago and really beyond resale.
Aug 02, 2009 | Sewing Machines
Elna Carina service
I just had the same question for servicing of my Elna Carina. I contacted customer support for Elna and received the following e-mail: "Elna machines can be serviced by most authorized Elna dealers. If you need to locate an authorized Elna dealer in your area, please visit our official website at: www.elnausa.com and click on “Dealer Locator” on the top right hand side of the page."
Nov 06, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
547 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
