Question about HP LaserJet CM1312NFI Multifunction Printer Color 12 ppm Mono 8 p
Magenta color misalignement on HP Color Laserjet CM1312nfi MFP
Magenta is printed 1mm displaced in vertical direction to the top of the page. How can I correct the alignement ? Did color calibration several times and used HP original toner but it just didn't work. Is there a chance to calibrate the colors ? Or is the firmware buggy ?
spurs21
  • 26 Answers
SOURCE: No Color Suppy Error Code
Try cleaning the print connectors on the cartridge housing area with a q-tip. This should resolve your problem, or else try to run ink cartridge test on your copier. Let me know if this fix your problem.
Posted on Jun 08, 2007
sir fixalot
  • 146 Answers
SOURCE: HP Color Copier Error Code
Try turning off the device, and holding down the # and 6 keys simultaniously while turning the power back on. If that doesn't work reply back with the EXACT sequence of messages that display. I will continue to research the error code to provide a better solution.
Posted on Jan 02, 2008
Cogz
  • 1326 Answers
SOURCE: HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Posted on Nov 16, 2008
SOURCE: I am using a hp 4360 printer-I do not have a manual-
I'm not fully understanding what lights are flashing. Here is a link to the manual that you can determine what the light pattern means. Copy and paste this line into your address bar:
http://h10032.www1.hp.com/ctg/Manual/c01438085.pdf
Posted on Feb 23, 2009
goodgold
  • 389 Answers
SOURCE: HP 190 Cartridge cleaning not lasting
You should apply to service. The Fault is caused by wear-out rakel knife. This device which clean the photo a drum.
Posted on Sep 20, 2009
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Printing problem comes after 10 page or 50 pages after ,(cyan,magenta,yellow) color verticals 1and half inch line comes in print .
after printing 10* or 50 pages* at a time then you should off your printer for 15 minutes then restart it again.
*problems comes because your printer goes very hot
Jun 08, 2012 | HP LaserJet CP1215 Color Printer
HeLp! My HP CM2320nf MFP is printing blurry!
I had the same issue... and found this to finally work after reviewing many sites.
System Setup - Print Quality - Adjust Alignment
Apr 29, 2010 | HP Laserjet CM2320nf All-In-One Color...
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
My name is John HP 1015 MFP printer will not print Magenta.
This is caused by a dirty laser unit.
It is possible to clean the lenses and mirrors (with care not to scratch the surface silvered mirros AND not to disturb eany of the optical components)
There's quite a bit of dismantling to do to get to the laser unit, but if you work methodically (and remember to double check everything when you are 'rebuilding' the printer) it is certainly possible.
This is a common problem and also appens with HP Color Laserjet 1600, 2600, 2605, CM1017, and Canon LBP5000.
Dec 19, 2009 | HP LaserJet CM1015 All-In-One Printer
Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Jan 20, 2009 | HP (Q6473A) Print Cartridge for Color...
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet CM1312NFI Multifunction Printer Color 12 ppm Mono 8 p Logo
134 people viewed this question
Seeker5211
Seeker5211
