Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Leaking water from water dispenser
Turned water off. Ice maker continued to work, perhaps from residual water in unit. Now ice maker feed tube is frozen.
Why won't the water come out of the in-door water dispenser? Why won't my ice maker make ice?
Be thoughtful of any water leaks. Water leaking beneath the machine will damage floors.
If both the ice maker and water dispenser are not working it is likely the feed connection from the wall to the unit. The hose/ copper tube can get kinked or the valve at the connection at the wall internally plugged. Close off the water at the wall and using a catch remove the connection at the unit open the valve at the wall and confirm the that water flows freely through.
Check the filter of the water located usually at the front grill near the floor. If the filter is removed the water connection will buipass the filter.
It is not likely with both the ice maker and water dispensor that both electrical solenoid valves have failed.
26159659-bocfglvi4lojepqiax35xhd0-1-5.jpg Hope this helps?
Apr 10, 2016 | Kenmore Refrigerators
The fridge is leaking water and going onto the floor underneath the fridge how can l fix this problem
If equipped with Ice Maker and water dispenser we can assume that the water feed has developed a leak. To confirm protect the floor in-front of the machine pull the machine out from the wall and reach around behind and turn off the water feed. CAUTION the wheels from a full machine will scar the kitchen flooring. Mop up the water and dry out the floor.
If the water no longer returns than you can assume that the source of the water is with the ice maker or water dispenser.
If the water continues and the machine operates normally (freezer below 10 F and refrigerator < 40 F) then it is the defrost cycle. The good news the ice maker might be alright. The defrost cycle has a drain tube. About twice a day or less often the machine has an automated defrost that allows for the ice build up on the evaporator coils to melt and run through a tube to a tray under the machine. the water in the tray evaporates between cycles.
First check if there is any water collecting at the bottom inside the refrigerator portion of the machine. If so with the water turned off you can be certain that the defrost cycle water is not being contained with in the drain tube. It is common that the drain tube can either plug from lint etc or ice over, Included i will link a few videos describing the situation and depending on your model a course of action.
How to Unclog Refrigerator Drain Line
https://www.youtube.com/watch?v=4SEe5z9JrMU
Jan 10, 2016 | Refrigerators
Fridge will dispense water and ice but will not make ice
You question " Fridge will dispense water and ice but will not make ice" If its not making ice then how its dispensing the ice. This is bit confusing me,-------- as per your question i assume you mean to say, that its dispensing the watyer but its not making ice. ------------
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Apr 26, 2011 | Refrigerators
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 23, 2010 | Maytag MSD2651 HE Side by Side...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Ice maker does not make ice anymore. appears the tray is not filling with water. door water dispenser is still working
Apr 24, 2010 | LG LRFD25850 French Door Refrigerator
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water continues to leak from the ice maker into
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve may be staying open. It's on the back where the water supply is connected. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Jan 06, 2010 | Refrigerators
Auto Ice maker in Whirlpool fridge, not producing ice. I suspect the water feed line might be frozen since it was working fine two days ago. I haven't heard the water fill and the tray is empty.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Oct 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker won't send water to unit. Solenoid is good
Make sure the fill tube where the water goes into the ice mold is not full of ice. Your old valve may have been leaking and it will freeze in the fill tube. Other than than maybe start the ice maker working by filling it with water and see if it dumps and refills.
You can swap the wires on the inlet valves and try the water dispenser. The water should go to the ice maker letting you know the valve works and the line is clear.
Aug 15, 2009 | Refrigerators
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
