Question about Lexmark E220 Laser Printer
Lexmark E220 printer feeds multiple sheets at once- how to repair?
Printer prints perfectly but often (usually) feeds multiple pages through at once, regardless of paper brand or quality. Printer has not seen a large amount of use.
  • Peter Abbott Dec 03, 2012
    The problem was indeed with the paper separation pad.  It's on the back of the E220 and is easily accessed by removing the rear paper feeder cover.  It has 2 clips that retain it and is easily removed by squeezing both clips inward at the same time.  There is a cork pad on the paper separator that wears down and causes multiple sheets to feed.  I purchased a new separator pad assembly on line (less than $10), replaced it, and printer works as new!  Cheap fix, and one less printer in the landfill!
3 Suggested Answers
pdouglasss
  • 125 Answers
SOURCE: Lexmark Opra M410 Laser
Your printer has a separation pad that is worn out and needs to be replaced. This pad prevents the printer from feeding multiple pages. It is located in the inside front of the paper tray Assembly.
Posted on Jan 07, 2009
  • 108 Answers
SOURCE: Lexmark Z715 printer feed paper
The feed rollers might be dirty from the ink. Try cleaning them with a Q-TIP with a little isopropyl alcohol.
Posted on Jul 31, 2009
Dell P1500 Laser Printer
You need to replace the separation pad. This printer is made by Lexmark, so parts are available through many vendors. The part number for the pad is 56P0691. You can google the part number to find a vendor closest to you for the best shipping charges. It is relatively easy to replace. Good luck.
Jun 30, 2009 | Dell P1500 Laser Printer
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
Printer feeds all the paper at once.
sounds like the separator pad is either missing or dammaged
Feb 10, 2009 | Lexmark Z715 InkJet Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Feeds multiple pages
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | Brother MFC 6800 All-In-One Laser Printer
Paper Jam C84
Was the printer feeding multiple sheets at the same time, so that the sheer thickness of the wad caused the jam? If so, look into the slot where you load paper (this is called the automatic sheet feeder or ASF). You should see a small roller with a rubber coating. This is what pulls the sheets into the printer. Put one sheet of paper into the ASF and do a print. The Windows test print facility is convenient for this: start-control panel-printer and faxes, then right click your printer icon and select properties, then test print). If this works OK, put two pages into the ASF, then three etc. Observe what happens. If at some point more than one page is pulled in, it infers that the ASF is not working properly, in which case you will need to consult a technician (or have a go yourself at dismantling the printer). If the one-two-three-four etc page test doesn't produce a multiple feed, all it probably means, is that static electricity is holding the sheets tightly together. Make sure when you put a wad of paper into the ASF it has been fanned.
Report back on what you find, or if you have any queries on the above.
Jan 22, 2009 | Epson Stylus C84 InkJet Printer
Jan 06, 2009 | Lexmark Optra M410 Laser Printer
Multiple paper feed
The paper separator pad is worn out and will need to be replaced. It's a rubber pad that rests behind the paper pickup roller and is supposed to prevent what you're experiencing. Contact your nearest authorized HP repair center.
Apr 13, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
Lexmark E220 Laser Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
