Question about Ryobi Garden
Fuel mixture what fuel is used
    Sergeant:
    Champion:
  • 278 Answers
Your manual will say 32:1 40:1 or 50:1 mixed fuel and 2 cycle oil.
Posted on Oct 29, 2012
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
What is fuel mixture on a 25cc craftsman weedwacker
I always mix it 40:1 so that the piston will always be lubricated and after I finish cutting I empty the gas tank and then restart machine so as to keep the fuel filter clean.
David
Sep 21, 2014 | Poulan Pro BVM200VS 25 cc Gas Powered...
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have an older echo blower. just had it tuned up and adjusted and still running poorly. just wondering if it is my fuel mixture of 25;1
25:1 may be too rich a mixture. Clean your spark plug well. Then get some good synthetic 2 stroke oil and try a 32:1 mix or a 40:1 mixture. Here is a fuel mix chart for you use.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
May 15, 2011 | ECHO, Inc. PB-251C Handheld Blower
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
Diagnostic warning light.....diagnostic done at kia dealer... no obvious but told it might be mixture problem as they had seen same before. Any ideas?
Hi.
Mixture problems can be caused by a number of factors and faults. A computer module, the PCM, determines the mixture using data from different sensors. Re-circulated gas is also used to determine the mixture.
If the problem only happened at cold, then check the MAF (mass air flow) and (IAT intake air temperature) sensor, and also have the vacuum system tested for leaks, hat can affect the mixture and make a difference, particularly when idling.
If the problem reported by the error code was mixture related, then a common cause is often the EGR valve, that regulates gas re-circulation. In this case the engine will be running rough at idle and when driving.
More problems that can return mixture related codes can concern:
Fuel injector problems (voltage , leaking injector, dirty injector). In that case more codes may be returned. Excessive or insufficient fuel pressure due to fuel lines, pump problem, or bad fuel pressure regulator. Gas recovery system, vacuum leaks and EGR valve. Air leaks from air intake mainfold (after sensor), or defective MAF, IAT. If sensors are faulty, then you will get more codes. If the car recently runt out of fuel, or if the fuel cap is defective you can also get an error related to mixture. Exhaust leaks before reaching the O2 sensors. Timing problem.
If the only problem was a mixture related problem, then wait to see if the code comes back. The engine warning light will turn on. In that case check for additional codes and report the code here.
Things are different if there are more codes. Also there are differences if the mixture is too rich or poor.
Regards.
Feb 04, 2010 | 2004 Kia Rio
Fuel mixture for Poulan 245 and 306 chain saw's
245 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/30945e6822106f5388256b3500246efa?OpenDocument
306 here
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9a98d7ae6c77deaf88256b350024ae42?OpenDocument
I use 50:1 in everything.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Jan 26, 2010 | Poulan Garden
Fuel oil mixture
use a 32:1 mixture which is approx 4oz 2cycle oil to 1 gal of gas. you can also add an ounce or two of of a fuel sys cleaner to your fuel mixture for a good cleaning of the carb to remove any gum or varnish build up which could cause poor engine performance. hope this helps you
Aug 08, 2009 | Homelite Garden
Won't stay running for more than 10 min
Not true. It is important to read the package and fuel/oil mixture ratio ie: 40:1, 50:1, 32:1, as long as the mixtures are the same, you can use one tank for all of the 40:1 tools, one can for all the 50:1 mixtures, one can for all the 32:1 mixtures. essentially all the 2 stroke oils are the same, the numbers just designate parts of oil(quantity) to parts of gas.
Aug 02, 2009 | Garden
Garden Logo
18 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
