Question about Brother XL-5500 Mechanical Sewing Machine
Needle not catching bobbin thread at all
The needle isn't catching the bobbin thread at all, does anyone have any solutions? I have rethreaded from restart, tried new thread and bobbin and checked direction of bobbin.
  • Brother Master
  • 1,564 Answers
Did you change the needle? If that doesn't solve the problem then it's probably out of time. Take it in for repair.
Posted on Nov 12, 2012
  • 33 Answers
SOURCE: I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Posted on Sep 04, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
danne
SOURCE: needle and hook out of time.
I think this is what is wrong with mine as well... did any one offer you a solution? if so could you get back to me on I think i put my bobin in wrong?
Posted on May 30, 2007
SOURCE: The bobbin thread is not
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Posted on Aug 02, 2010
  • 475 Answers
SOURCE: I have a brother pe 770 and the bobbin will not
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Posted on Dec 15, 2010
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
BOTTOM THREAD WONT CATCH
are you sure you have the bobbin in correctly? I mean most machines require that the bobbin un-spool in a specific direction to work properly. Also make sure your needle isn't damaged or bent and is inserted fully into the needle bar.
Good luck
Jul 29, 2012 | Sewing Machines
The manual says the top thread should catch th bobbin in a loop but mine won't. what can i do ?
Make sure your needle is fully inserted into the needle bar and isn't bent or blunted.
Jul 19, 2012 | Brother Sewing Machines
Needle wont catch thread from bobbin
check the needle to see if it's in backwards---flat side should go to the back of the machine
make sure the needle is inserted all the way up into the needle holder.
make sure it the right needle for the machine to use.
Mar 31, 2012 | Sewing Machines
Bobbin thread isn't catching correctly?
have you tried changing the needle?
try adjusting the top tension
Mar 16, 2012 | Singer CE-200 Quantum Futura Computerized...
My thread keeps breaking at the end of my sewing session. not sure why, I've been sewing blocks for a quilt and I've tried to change the thread
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 12, 2011 | Sewing Machines
I have threaded up my machine and have started to sew. The thread on the back of the fabric keeps catching and bunches up. What's going wrong?
try a new needle
keep a check on the thread take up lever that the thread doesn't come off of it
rethread the machine to make sure that the thread isn't catching on anything
clean under the needle plate for loose thread or lint & in the bobbin area also
make sure the bobbin is inserted correctly
Aug 04, 2011 | Bernina 1008
My machine is new and worked briefly but now . . . . the machine is threaded correctly and the bobbin is placed correctly. When turning the knob for the initial pick up of the bobbin thread, it does not...
You have described your problem just fine. Have you just changed the needle in your machine? If so, check it is in the right way, you want the flat shank to the back.
The needle has a scarf (scoop out) at the back - if it is facing to the front then the rotary hook (bit that goes around the bobbin and catches the top thread) can't catch the needle thread behind the needle.
Also check needle is fully up into the housing, this could also cause problem.
I'd suggest that you visit www.sewingabout.com and check out the pages on general sewing machine use, care and threading up, lots of helpful pictures and information which may be of assistance to you.
If it isn't your needle backwards (very easy to get wrong, happens all the time), then the timing could be out, which isn't so easy, but as its new I'd be very suprised if this was the fault. Just check needle, make sure top and bottom threads are threaded correctly and have another go. Also, remember to turn flywheel towards you.
Jul 14, 2011 | Singer 7444 Mechanical Sewing Machine
I had to change the needle when I retreaded it it doesn't catch from the bobbin, the clutch is in the proper position, I've re threaded and re inserted the bobbin, but it doesn't stitch
NEEDLE TROUBLESHOOTING:
Is in backwards, Needle mantra is "insert needle with the flat shank to the back of the machine". Needles have a scarf (cut out) at the back where the hook swings through and catches the thread, if it isn't facing the right way, then the thread can't be caught by the hook.
Is it fully up into the needle housing?
Is it the right needle for the machine. Most domestic machines take the standard 705/130H system needle.
Is it bent, blunt or burred, always start each job with a new needle from the packet, choosing the right sized needle for the fabric weight, and sharp for wovens, or ballpoint for knits.
Good needle chart, threading and machine cleaning info at www.sewing.about.com if you don't have a manual.
If you have tried all these things and still no joy, then it is possible that the machine timing has been knocked out, ie the sequence between needle at it's lowest point and when the rotary hook swings around and catches the thread from the back of the needle. But try the above first and I hope it resolves your problem. Timing is best left to a trained technician.
Apr 12, 2011 | Singer 3116 Simple
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 26, 2010 | Necchi Sewing Machines
Brother XL-5500 Mechanical Sewing Machine Logo
160 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
