Question about Sony BDP-S300 Blu-Ray Disc Player
I want to be able to play all my recorded dvds but get message
I have a sharp blu-ray player model number BD-HP21X which I want to be able play all my recorded Dvds' on when I put the recorded DVD in the player a I get a message coming up incompatible disc I take this message as because this machine has copyguard installed on it cannot play this disc I want to know how I can disable copyguard or macrovision from the player so I can play all my own recorded dvds on this machine.
Thankyou
  • 2 more comments
  • dolphinlo510 Jan 04, 2009
    I am hoping there is a backdoor to disabling the DVD player so i can play my own dvd on it. Thankyou Wayne
    This hasn't fixed my problem
    I am looking for the codes to unlock my SHARP BLU-RAY PLAYER MODEL NUMBER BD-HP21X So I can make it region free and turn of macrovisoion Thanking you for your help
    It plays a dvd from the video shops but not my recordable movies i have that is why i need the codes to unlock the player so i can turn off region code and macrovision. Thankyou
  • 10,594 Answers
Let me know what kind of recorded DVDs you are playing on this player?
Are they home made without copyrights are copy DVD of some movie?
If those DVDs are home made and has no copyrights then set your DVD burner software to region free and try.
Posted on Jan 04, 2009
    Genius:
  • 1,239 Answers
HI CHECK THESE Steps:
1. Remove the screws that hold the top case on the dvd player. There will be a couple of screws on each side of the player and a couple of smaller screws on the back. They will most often be BLUE RAY head screws.
2. Once the cover is removed, push the eject button to open the cd tray and get it out of your way.
3. Unplug the player from the outlet.
4. Take the can of compressed air and blow out the entire inside of the case. Make sure to blow inside the carriage and around any moving parts of the dvd player including tracks, tray, gears, etc.
5. Check the inside of the carriage using a small flashlight and look closely to make sure there is not debris caught in the spindle or other places like hair, large clumps of dust, dirt, and anything else that should not be there. If you see this kind of material remove it with tweezers and repeat blowing out the inside.
6. Pour a small amount of the rubbing alcohol into the cap and lightly dip a cu-tip in it and shake off any excess.
7. Now and clean off the optical lens (which will look like a small glass bubble in the middle of the carriage) with the cu-tip. Repeat this process a couple of times using a clean cu-tip each time.
8. Let air dry for 2 minutes before plugging the player back in and closing the tray.
9. Replace the cover and clean your discs before placing them back in the player. Test to see if the problem has been fixed.
You should clean your dvd player out at least once or twice a month for good preventative maintenance which will extend the life of your dvd player.
  • ABHISHEK.C
    ABHISHEK.C Jan 04, 2009
    reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down buttons at the same time until it says "Bye" on the display. When it shows the clock it is off - wait a few seconds then turn it back on - you should see the initial setup asking you to choose a language.
    Note: You may have to flip down part of the front panel to reveal the channel buttons.
      player completely apart and white gears had dirt in them. This was preventing the player from spinning. Use dust remover and clean the whole inside and now it WILL works great.
  • ABHISHEK.C
    The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
    1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-25 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
    2. The cd tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull and push on the cd tray.
    3. The small gears are plastic and often break, this will cause the players other parts not to move and function properly also. They are hard to get to, but inexpensive to replace from the manufacturer. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
    4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are a pain to put back on also. There are usually 2-3 of them inside your player.
    5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might as well buy another player unless you can find a great deal on one someplace. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc.
    6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on. Check these two components if you are having problems with your cd tray.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, couple of ideas to consider:
  • could these "recorded DVDs" be played on some other DVD players other than the BD-HP21X or the DVD recorder/burner they were made on;
  • were these "recorded DVDs" finalized?
Good luck and Thank you for using FixYa.
    Sergeant:
    Champion:
  • 239 Answers
Try to play a regular cd see if it works
    Scholar:
  • 86 Answers
Hi!
You can actually bring this to a technician who can have the system hacked and "modify" it so it could play all discs regardless of regional/global restrictions per disc. (Burned/Ripped as well could be played) Or you may scout for a "Shark" that will try to override and hack the system with an adjunct installed peripheral.
Thanks and Good Luck! =)
  • Anna Marie Abueva Jan 05, 2009
    Hi!
    Sorry for the late reply, you actually don't have to make any adjustments on your blu-ray disc player.
    Make the adjustments when recording your DVDs.
    Make sure that when you record it, it is on region 0, so that it is region free. Your recorder actually has 5x allowed modifications in changing region codes. So make sure not to mess up.
    If messed up, not even hacking it open could fix it.
    Thanks and good luck! =)
    Top Expert:
  • Sony Master
  • 78,267 Answers
When u say your recorded DVD's do u mean copies u have made with a computer burner and a decoder program like DVD43? if so they should play because the copyguard has been decoded enable to copy the orig copywrited movie, please explain what u mean a little more to the point, be careful though, if u are copying movies that is a violation of Federal Law and international law.
  • yadayada
    yadayada Jan 04, 2009
    My new Blu-Ray (Memorex brand made by Imation)) plays copies just fine, they where made years ago (before they changed the law) with Oneclick and DVD43 decoder.
    President:
  • 1,990 Answers
I Have not Heard of anyone who has been able to accomplish this with this Player Yet. Believe it or Not, Some of the Lower End Models CAN Play Copied DVD's with No Problem Though!
    Sergeant:
    Novelist:
  • 326 Answers
The only option is to reinstall the firmware.it will read if u dont select extented capabilities while installation.
  • technodeal Jan 04, 2009
    most of the time it doesnot support the recorded discs but while reinstalling firmware if u dont select extended capabilities it sometimes starts reading copied discs disabling the copyguard.give it a try.
    Genius:
  • 2,920 Answers
You cant disable it. if you try to it wont play any disks at all. it wont play copied disks.they are made not to
  • Ronnie Houston Jan 04, 2009
    there really is no way to disable the copyright coder. if you do you will ruin your player..take my work for it . buy the movie new and then you wont mess up your system
I bought a Samsung BD C6900 from USA designed for region 1 and A . Living in Europe I cannot play my european DVDs and BDs ? Are there any solutions to change the region code ?
Here is a solution: http://www.videohelp.com/dvdhacks/samsung-bd-c6900/10895
Please note, however, that even after region code hack, it may remain NTSC only, so if you are planning to play European DVDs recorded with PAL system, it may not work.
Feb 27, 2011 | Samsung BD-C6900 Blu-ray 3D Player
My Sharp model BD-HP210U will not play the new Blu Ray DVD Avatar. Do I need to upgrade the software?
I did and my problem is fixed with this model. On a side note I wish I would have got the models with Pure Mode, but the 210u was a steal at 100 bucks.
May 03, 2010 | Sharp BD-HP21U Blu-Ray Player
Hi i have a sharp hp22 i ham trying to play normal dvds on it ? is that possible
All Blu Ray players that I have dealt with are what is termed "backwards compatible" which means they play Blu Ray, standard DVDs,music CDs,MP3s,recorded CDs and DVDs, etc. yours should have no problem reading and playing back your "normal" DVDs. Good luck !
Dec 27, 2009 | Sharp BD-HP22U Player
Please need to find where to download firmware upgrade for the bd-hp21x as it will not play some new blu rays ?? was told to download upgrade and burn to dvd and should fix ?? but cannot locate the...
Follow this step by step guide to download the firmware:
  1. Click here to visit the support page for your player. The following page should open: dbe7eb4.jpg
  2. Click on the "Attachments" tab:9a8a0d3.jpg
  3. Then click on "Software & Drivers" and then on "Go":c072d01.jpg
  4. After that the link for firmware download will appear:eb47827.jpg
  5. After accepting the agreement, download will start. Save this file and update it according to the instructions. If you do not know how to upgrade, just post it as a question and I'll try to provide instructions for that as well.
If you find this helpful, don't forget to rate.
Dec 20, 2009 | Sharp AQUOS Blu-ray Disc Player
BD-HP21U problems playing discs
You have inadvertently downloaded the US (or other region) version of the firmware. Unfortunately if you try and download the UK version the HP21 just tells you you have already installed it. I was told mine the only way to reset it is for it to be sent to Sharp or you can wait for a new firmware update.
Jul 16, 2009 | Sharp AQUOS Blu-ray Disc Player
My Sony Blu ray can't play normal DVDs in my region - Africa. How do I change the region coding just for DVDs?
It's not possible to change the region code in the Blu-ray Player.
BD media does have region codes. But, unlike current DVD players, the region codes for BD media use letters instead of numbers to indicate a particular zone or region where the discs can be played.
The BD region codes are as follows:
Region A: North America, South America, U.S. Territories, Japan, South Korea, Taiwan, and other areas of Southeast Asia
Region B: Europe, Africa, Middle East, Australia, and New Zealand.
Region C: Asia (except for Japan, Korea, Taiwan, and other areas of Southeast Asia)
Jun 16, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Sharp Blu-Ray model BD-HP20X locked to region 4 how to unlock ?
Well I Checked my data resources and saw that there are no hacks or tricks for Sharp yet... the only thing you can try doing now is to ask your Dealership if they can unlock the regions for you. I've searched everywhere but couldn't find anything for newer models like HDDVD or Blu-Ray players.
Sorry T_T But let's hope someone might be able to help as well..
Mar 31, 2009 | Sharp AQUOS Blu-ray Disc Player
Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
Dec 25, 2008 | Televison & Video
Sony BDP-S300 Blu-Ray Disc Player Logo
364 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
