Question about Water Heaters
I have a isar he24 boiler that needs the pressure topping up, i have put the filling loop on but for the life of me don't no if to turn the small screw on right or left, any ideas?
  • 234 Answers
SOURCE: I need an Instuction manual free to download for
http://www.screwfix.com/talk/thread.jspa?forumID=25&threadID=27577&messageID=268842
I hope this help you.
Posted on Mar 19, 2009
  • 30 Answers
SOURCE: I can't turn the bar pressure up on my Vaillant VCW 221 Boiler
on the pipework below there may be a silver braided hose with one or two valves on the end. turn the valve(s) so the handle is inline with the pipe this will allow water from the mains supply into the heating circuit , remember to keep an eye on the pressure gauge. fill the system to 1bar cold then shut down the valve(s). turn on the boiler and it should be ok, if you lose pressure again then you may have a leak somewhere which needs to be found.
Posted on Mar 30, 2009
gary1121
  • 332 Answers
SOURCE: how do I re-pressurise the boiler via the temporary filling loop
you may need to hook a hose to the drain and to a spigot depending on your water pressure in your home and back feed the unit to desired pressur,, does t have an auto matic feed valve or just a shut off valve,,
Posted on Jun 21, 2009
  • 54 Answers
SOURCE: I have a VOKERA 24 boiler the Linea range which
Water logged expansion tank ( ruptured diaphram in tank) or wrong size tank. This caused the excessive pressure in the system causing the relief valve to open. Also, air in the system causing flow to stop, Both conditions will cause boiler go out on safety.
Posted on Sep 13, 2009
mrhotandcold
  • 248 Answers
SOURCE: Combi boiler will not fire up for hot water or heating.
check tops of spindles at radiator valves for leaks easy repaired set pressure to .8bar setting at 1.5 may be make overpressure and blow off through high/pressure releasese valve
Posted on Dec 03, 2009
Baxi boiler 80E low pressure on boiler how to fix it?
Silver flex hose may be the (correct) filling loop. There may be a valve at each end of it, maybe just one at one end.
Open the single valve slowly and LISTEN for the sound of water entering the system, and LOOK for signs of the pressure gauge rising.
On the dual valve version open the first, then open the second slowly as above. Close both valves when pressure is adequate. Adequate is determined by the specifics of your system, but note that more pressure DOES NOT mean better showers, etc.
It should only take a few seconds to top-up, any longer indicates a significant loss of fluid from the system.
Jan 28, 2013 | Water Heaters
My pressure is low on my halstead eden cbx24 boiler, i can find the loop to fill it up but dont know where to put the water in, can anyone help?
Do you have a sight glass that shows water level in boiler on this loop? If so is it marked where normal water level is supposed to be? There should be a water line connected to boiler with a valve on it. This will be a manually operated valve unless it has auto fill control. Locate this valve and slowly add water until level in sight glass is back where it should be,then shut valve.While you are doing this the boiler should be at operating temperature because hot water expands and you don't want to overfill. There should be a temperature and pressure relief valve on top of your boiler to prevent unsafe conditions but I wouldn't count on it working properly if it is very old. My main concern is for your safety so if you are unsure of something don't do it. If your boiler has a automatic water make-up on it then you need to have a service tech. find out if it's not working,and repair or replace it. I hope this helps you. Thanks
Nov 24, 2010 | Water Heaters
The water pressure on my Greenstar 25Si Worcester Bosch combi boiler is so low that the shower won`t heat up. Can someone please tell me how to increaese the water pressure as there doesn`t seem to be an...
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
Feb 06, 2018 | Water Heaters
Nov 30, 2009 | Water Heaters
Low pressure on recently serviced Vokera 14/48se.
Identify the cold feed to the boiler, then look for a tap/service valve which when turned lets water into the boiler via a fill loop to pressurise it. 1-1.5 bar is ok
ju
Nov 05, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
I have a VOKERA 24 boiler the Linea range which was working fine until i notes the pressure was a little under 1.5 Barr. I topped it up the pressure with the filling loop every thing was fine. The next day...
Sep 13, 2009 | Water Heaters
How do I re-pressurise the boiler via the temporary filling loop
Jun 15, 2009 | Water Heaters
Water Heaters Logo
1,132 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
