Question about Kenmore HE2 Plus Front Load Washer
F 1 flashing on panel , washer wont turn on. - Kenmore HE2 Plus Front Load Washer
  • Tom posmituk Nov 10, 2012
    I unpluged the washer for 24 hours ,plugged it back in and it works ,who knew.?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
That is a bad error code. What is your model number?
Posted on Nov 10, 2012
What does LOC mean on kenmore elite washer ?
Press the Options and Select buttons at the same time and hold for 3 or 4 seconds to unlock the control panel. Best Wishes
Sep 04, 2014 | Kenmore Washing Machines
Replaced the whole top panel. now start lights only flash wont start washer
You might have blown a fuse on the circuit board or fried a transistor on the board
Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer was running doing load and heard a solid beeping the h and f were flashing on panel heard pump sound like it was working but machine had already drained water unplugged and waited plugged in socket...
This error code means"No water detected entering machine or Pressure switch trip not detected".
Is the machine getting any water? Check that the water supply is turned on.
Press pause cancel twice to clear the display.
Try to run another cycle.
Let me know if I can help with anything else.
Mar 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clean light blinks 7 times dishwasher wont turn on
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
Jul 23, 2009 | Dishwashers
Washer fills and drains but won't aggitate or spin
Seven flashes means the washer did not sense a lid opening. Check the lid switch.
May 30, 2009 | General Electric WJRR4170GWW Top Load...
Washer wont turn on flashing de
Open the washer and clean the drain pump.
May 19, 2009 | LG WM1814CW Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Flashing power light
I have just had a mechanic out. I have the same problem. It turns out that the front panel is gone on it. I had it in storage, and it got damp. It is not worth getting fixed, as it will cost about 300 euro!!
Mar 24, 2007 | Hotpoint Aquarius WF210 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
