Question about Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120
My pc would not boot up
I guess my son intermittently turned ON and unplugged the PC without shutting down properly. Now am having black screen after booting.
  • Acer Master
  • 673 Answers
Re-install The OS....
Posted on Oct 27, 2012
Giddion
SOURCE: Acer Veriton 6800 PC Desktop will only beep will not boot.
reseat ram for a fast beeping and disconnect the power supply both the big and 4 pin connectors for 2-5 min plug in and boot. Plus you do not have to have pairs of mem only if you wand double data rate
Posted on Jan 10, 2008
SOURCE: ast180-ud360a will not boot up
I suspect bad memory. Have you worked on it recently? Make sure the memory is in and seated properly. Same with processor and adapter cards.
If you havn't worked on it or opened it, and don't feel comfortable opening it up, you might want to take it to a computer repair place.
Posted on Jan 13, 2009
  • 5 Answers
SOURCE: acer veriton beeps continiously when it stars without booting up
just check your memory
Posted on Oct 07, 2009
Vaio Tech
  • 166 Answers
SOURCE: PC difficultly boots
it look like you have to many ram or set the ram timing rong restrat the pc and press f2 and del at the bigining and after load the bios go to the last exit and make load defaults and say yes and restart and see if you get the problem solve thanks
Posted on Nov 07, 2009
CA-CPU-Guy
  • 8 Answers
SOURCE: I have an acer aspire z5610 desktop pc and I need
I've looked at the ACER Website and it appears that you should try to boot to SAFE MODE by pressing F8 at boot. If you're able to do so, you should find the ACER eRocovery application in the Programs Menu. This may allow you to recover from a hidden recovery partition, or it may require you to have made a set of recovery discs with the eRecovery Utility that came with the system. If you did not do so, then your only alternative would be to contact ACER and ask if you can purchase a set of recovery CD's.
I've had a lot of luck contacting ACER Corporate at the following phone number and pleading my case for the product owner and gotten great customer service this way, much better than calling the regular support number.
Acer America Corporation 333 West San Carlos Street Suite 1500 San Jose, CA 95110 (408) 533-7700 - Phone
Posted on Aug 27, 2011
Testimonial: "Very informative, detailed and concise "
When I turn on my laptop pc every couple days a black screen will come up and the laptop stops processing. Why? How to fix it?
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
Dec 25, 2012 | Acer Computers & Internet
Have tuned on laptop but just black screen with cursor
Windows is not loading properly ..... Turn off laptop ..... turn it back on ...... and start hitting F8 key till you get a screen asking whether to boot menu..... select boot in safe mode...... and check it it boots up ... if it boots then shut it down . And then turn on again and check.....if it still get stuck use your windows CD to repair windows......
Nov 01, 2012 | Computers & Internet
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
Dell Inspiron 1545. When booting to vista the screen goes black. When booting to safe mode the screen works normally.
Please reinstall the Video Driver and check if the same issue persists. If the issue started within last 90 days, you can try the System Restore
Jul 01, 2010 | Computers & Internet
When I re-boot my PC, my monitor blinks on and off
It's normal behaviour - it blinks because during boot the pc starts with the default VGA driver, then unloads it (the monitor shuts down as the video card is disabled) then load the appropriate video driver (the monitor starts up again as the video card is activated properly).
May 06, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Hp tx 1000 black screen please hel
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Nov 28, 2009 | HP Pavilion Tablet Notebook
DOES NOT START SHOWS BLACK SCREEN
do a power drain
- shut down the comp, unplug the adaptor and unplug the battery
press and hold the power button without any power connected to the comp
- plug the battery and plug the ac adaptor and turn on the comp
Oct 04, 2009 | HP Compaq nc6220 Notebook
Usb power issues
Some systems will try to boot up on a usb device such as an IPod or a external hard drive.
It should be unplugged to get it to boot properly.
Oct 31, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120  Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
