Question about HP OfficeJet Pro K8600 Printer
How to print with black ink only on hp officjet pro 8600 plus
  • rcorreaone
    rcorreaone Oct 27, 2012
    Is there a way to bypass the color inks and print only with black ink on the hp officjet pro 8600 plus hp
  • 4 Answers
SOURCE: HP 3210 black ink problem
I just posted my problem and found the solution on a different web page. It is this and it WORKS
All you have to do is HOLD DOWN FOUR BUTTONS AT THE SAME TIME: ( OK, Cancel, Black , Color ) and turn the power off. Do this at least twice and the unit will power up and go to maintenance. Then it was back to normal.
HP gives you a procedure that doesn't work! They just want to sell you a new one. They must know the solution if and old woman like me can figure it out with help from other people with the same problem
Posted on Jun 26, 2008
  • 133 Answers
SOURCE: Black ink not working on HP C5180 Photosmart
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the HP website, to see what solutions are being offered for various printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
Posted on Jul 04, 2008
SOURCE: black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
Posted on Jun 11, 2009
SOURCE: HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Posted on Aug 17, 2009
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
Aug 31, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
How do I correct my problem with black vertical lines on my officejet 8600 printer?
Try cleaning the print heads using your HP maitenence program of by going into your printers section of the start menu.
Sep 23, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
Can i print with black ink only on hppro 8600
if you go into print settings you can print in greyscale ,but even that uses colours.printers are obstinate creatures.youll have to renew any depleted inks
Sep 02, 2014 | HP Officejet Pro 8600
How do you remove printhead?
Most HP printers include the print head with the ink carts. Replace the ink cart, get a new print head.
Sep 01, 2014 | HP Officejet Pro 8600 Plus e-All-in-One...
Why does my Officejet Pro 8600 have lines across colour printing which do not appear to be removed when I clean the printheads. Any advice?
I've noticed this on my all-in-one HP Office Jet. And though I had a little black ink left, I went ahead and installed a new black ink cartridge. Cleared up the problem. You would think what does black ink have to so with color issues but black is used in the color process. Maybe someone with more knowledge on color balancing may be able to answer that. Also, sometimes it may take several cleanings of the heads to clear them. It also depends on how old the printer is and how often it's used. So these are educated guesses but as I originally indicated my issue was due to black ink that either was old to begin with or had been in long enough to start causing issues.
I hope this helps.
Jul 29, 2014 | HP Officejet Pro 8600
Refilled ink cartrige still showing empty is their any way to reset printer
Regarding your HP Officjet Pro 8600 printer and refilled HP 950/951 ink cartridges and the "low ink" messages. Depending on your ink refiller (or if you did it yourself?), a replacement chip may or may not have been installed with the recently refilled cartridge(s). Refer to picture on our support site to first determine which type of cartridge configuration you have, then refer to the applicable section to address the current cartridge error(s) or printer issues.
http://inkjet411.com/?page_id=1999
NOTE: Costco USA's Ink Refill service now 'chips' all refilled ink cartridges which fully restores all functions to that of a regular HP (OEM) ink cartridge and customer experience. For USA ink refill store locations and details on ink refill pricing:
Costco USA Ink Refill Service (all 453+ stores): http://www.costcoinkjetrefill.com
Fry's Electronics Ink Refill Service (all 34 stores): http://www.frys.com/ads/page51
Micro Center Ink Refill Service: http://www.microcenter.com/site/content/refill-service.aspx
Refer to Section A if your refiller attached a new replacement chip (green in color) onto the cartridge. Refer to Section B if only the original HP chip is attached.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations). We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested! HP original/genuine ink cartridges can be identified by the visible HP logo on the front label of the cartridge.
HP 950/951 Ink Refilling & Additional Cautions:
http://www.youtube.com/watch?v=zOCC3h0OFiI
Questions regarding the use of refilled ink cartridges: http://www.inkjet411.com
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Mar 31, 2014 | HP Hewlett Packard Officejet Pro 8600...
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
HP OfficeJet Pro K8600 Printer Logo
1,413 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
